Suspension - Mustang Evolution
Old 03-12-2012, 01:54 AM   #1
Poppavoltron's Avatar
I'm a novice at this but just want a little hobby to tinker around with. I have 92 Lx convertible suspension is lowered. Handles good but can't go through a dip or bump without feeling it. So my question would be what's a good performance suspension with a comfy ride? Any help is is appreciated . Thank you
Poppavoltron is offline   Reply With Quote
Old 03-12-2012, 12:57 PM   #2
Re: Suspension
comfy and performance usually dont go hand in hand when it comes to mustang suspensions. You could go with a slightly softer progressive spring (say 500 rate max) and it would be ok.
replacing all the worn out rubber bushings will help (go back with oem) with the ride quality. Most also assume the springs are the cause while it can also be the shocks/struts that are worn out causing harshness (not collapsing as they should or froze up etc)
you should be able to find a nice set of springs for 150-250 and shocks/struts for ... well just depends on the brand but for a good price.
Old 03-12-2012, 02:16 PM   #3
1995boss's Avatar
Looking into late model restoration. Just brows around. And it would deepened on the use for the car.
1995boss is offline   Reply With Quote
Old 03-12-2012, 03:32 PM   #4
Thank you so much !!! Can't thank you enough. I'd rather go more performance then comfy. Anything is better then it is now. I really appreciate the help.
what suspension parts to put power to ground?? mhobbs 1996-2004 Mustang GT 8 03-09-2012 04:29 AM
Anyone know about Tein Suspension 1995boss 1979-1995 Mustang GT 8 03-06-2012 09:52 AM
Suspension Upgrades? mchilliard28 Pre-2005 V6 Mustang 4 03-04-2012 03:33 AM
Suspension help Venomouz831 Pre-2005 V6 Mustang 4 03-02-2012 07:04 PM
Balljoints, struts, suspension, etc Ajmt719 Pre-2005 V6 Mustang 28 03-01-2012 05:25 PM
05:14 PM
