strut question - Mustang Evolution
Old 03-12-2012, 07:00 AM   #1
fox87's Avatar
strut question
Wondering if someone could answer a question. I just finished getting my 87lx on the ground after 6 years of being of jacks. I lowered it 1 and a half inches with adjustable struts. I noticed the strut is sticking up higher now coming out of the tower at least an inch and a quarter above the nut. I am concerned I will have clearance issues when I get to the hood. Is there a way to adjust it or did I mount it wrong?
fox87 is offline   Reply With Quote
Old 03-12-2012, 07:50 AM   #2
Re: strut question
Pictures of how you mounted it?
Old 03-12-2012, 09:08 AM   #3
fox87's Avatar
I will have to wait till I get home. I will post a few then. Thanks.
Old 03-12-2012, 01:07 PM   #4
fox87's Avatar
Here are two pics I had on my phone now. I can rake more when I get home. One of the brakes and strut. The other is a close up of the top of the right strut before I tightened it.
Old 03-12-2012, 01:15 PM   #5
fox87's Avatar
Attachment 43330
Attachment 43331
Old 03-12-2012, 02:05 PM   #6
Re: strut question
I can't really see anything wrong in the photos.
Did you get the rubber bushing and steel washer in place on the bottom side?
Old 03-12-2012, 02:12 PM   #7
fox87's Avatar
Yeah and the metal spacer that's why I was concerned. Maybe I will take it apart again just to make sure it is assemble in the right order.
Old 03-12-2012, 02:17 PM   #8
Re: strut question
That would be the first thing to check and make sure those struts are the correct ones for your car.
Old 03-12-2012, 02:21 PM   #9
fox87's Avatar
Ok. I got them thru summit so I will check that. I think you may have already helped me though. I may have installed the steel washer incorrectly. Gonna look at that, thank you for your help.
Old 03-12-2012, 02:26 PM   #10
Re: strut question
You're welcome and good luck.
Old 03-12-2012, 03:50 PM   #11
fox87's Avatar
Hate to keep bugging but Ican you answer one more question? I was missing the washer. I found a few laying around but wasn't sure if it would work and I wasn't sure in which order I need to install the washer, spacer, and the rubber bushing. Here is a pic of how I have it at the moment. With the spacer in the strut doesn't come up thru the tower to put the top bushing, washer, and nut on. Been so many years I have forgotten how it goes.
Old 03-12-2012, 05:17 PM   #12
Re: strut question
Here an installation post with pics that will help you.
Strut Installation
Old 03-12-2012, 06:42 PM   #13
fox87's Avatar
Awsome that was what I needed. Thanks. Still a bit higher than stock but i think they will clear now..thank you again
ID:	43356   Click image for larger version
ID:	43358   Click image for larger version
Old 03-12-2012, 06:43 PM   #14
fox87's Avatar
LOL and they call them smart phones..dunno why it sent duplicates..oh well take care and thank you
Old 03-12-2012, 07:02 PM   #15
im sure worst case scenario you could trim the threads off the top.i dont remeber if the top is slotted or if the slot is really necceasary.but a cutoff wheel should take care of that.
Old 03-12-2012, 08:11 PM   #16
Re: strut question
You're welcome and good luck with your project.
Old 03-12-2012, 10:08 PM   #17
fox87's Avatar
I am not sure that I can cut them. They are adjustable struts with the dial on the top. Hopefully it would clear.
Old 03-13-2012, 05:57 AM   #18
Re: strut question
No, you definitely don't want to cut them then.
Put some playdoh on top of the stud and carefully close the hood to see how much clearance you really have.
A thin piece of plastic will keep it from getting into the adjusting mechanism.
Old 03-13-2012, 07:32 AM   #19
fox87's Avatar
Good idea I will do that when i get to that point. Can I put in shims if it doesn't clear?
Old 03-13-2012, 08:08 AM   #20
Re: strut question
I don't know why not, but I bet it will clear.
Old 03-13-2012, 08:40 AM   #21
fox87's Avatar
Hope so. Again thank you for your help. Take care.
gt40 question????? fordracing63857 1979-1995 Mustang GT 10 03-12-2012 10:39 PM
One question one request Silversky545 2005-2010 Mustang GT 0 03-11-2012 12:39 PM
1996 v6 boost question dhktactical Pre-2005 V6 Mustang 14 03-09-2012 11:04 PM
Bought some long tubes! Have a question Project Pony Pre-2005 V6 Mustang 1 03-08-2012 04:55 PM
Wiring harness question StevieScoops 1979-1995 Mustang GT 2 03-08-2012 05:49 AM
08:41 AM
