MAss air - Mustang Evolution
Old 03-12-2012, 08:51 AM   #1
choppa5307's Avatar
MAss air
I have a 91 wiring harness but some of the wires are cut could I use the mass air pigtails off this wire for my 88 Lx or should I buy the whole kit instead of putting things together
choppa5307 is offline   Reply With Quote
Old 03-12-2012, 10:06 AM   #2
Re: MAss air
You'd be much better off with a complete harness to prevent any future wiring issues.
You could piece it together as long as you followed the same wiring diagram throughout the system and crimp, solder and insulate any connections thoroughly.
Old 03-12-2012, 10:19 AM   #3
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Also need to make sure it has all the correct plugs, there are a few mass air harnesses but each one has different plugs, check the plugs down by the computer and the main plug(s) up by the brake booster. 9 times outta 10 since yours is an 88 it will have a black and grey plugin by the boosters and a green and grey plugin down by the computer. An 89 harness should be direct bolt in, newer harness may require you to swap out the dash harness as well. Some have just 1 plug up by the booster and I think 4 plugs down by the computer(I tried using a 92 harness in my 87 gt and no go because it had more plugs down by the computer, I had power when key was on but wouldn't crank) there's also a harness that has the correct plugins by the computer but then only 1 plugin up by the computer. You can normally find a good complete harness on eBay but are sometimes pricey. I lucked out and found a complete 89 maf harness for $50 bucks on CS cuz the guy was going carbed and just wanted it gone.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 03-12-2012, 10:54 AM   #4
Titus Wadicus
svtlx's Avatar
Re: MAss air
like trojan said, it up to u... and ur overall confidence level.
there's four wire's as u know....signal-in, signal-out, power, and ground.
out of the four, only two (signal wires) have to be tied into the harness/pcm plug. u can run the hot to any "ignition" powered wire.
ur 88 harness (if that's the one u wanna use) already has blank pins in the plug for the mass air. ford made provisions for the mass air way before they actualy put it in the car.
im gonna stop right there...
if wut im sayn sounds complicated.... pleeaase follow trojans instructions and get the whole kit.
if wut im sayn sounds simple, u can p.m. me or i can tell u better over the phone, how to route the pins into the harness.... as well as locating the correct pins.
---------- Post added at 10:43 AM ---------- Previous post was at 10:36 AM ----------
wow, i wish i had been around when u did ur mass air swap bud. i added mass air to my 87gt harness, then took out whole harness and put it in my 90v6 tbird for a v8 swap..... drove the car a few years then put that harness in my 92 stang coupe.
i read your post and im like....wow, u had a hard way to go...
---------- Post added at 10:54 AM ---------- Previous post was at 10:43 AM ----------
there are provisions for the hot and ground in the harness plug, im just sayn in general to make it easy to understand
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-12-2012, 11:10 AM   #5
Pete Jones
Oh yeah, I played hell finding the right harness heh. I had a pin kit from Granetelli but I didnt like it, I liked having the whole actual harness to just plug in and go.
90 LX hatchback
89 LX Notchback
Old 03-12-2012, 11:15 AM   #6
choppa5307's Avatar
This is wat I got
ID:	43317   Click image for larger version
Old 03-12-2012, 11:21 AM   #7
choppa5307's Avatar
These two plugs wasn't hooked up in my 88 to anything wen I got it
Old 03-12-2012, 11:44 AM   #8
Titus Wadicus
svtlx's Avatar
Re: MAss air
one of those operates your fuel pump and sending unit..... and if i remember correctly the other operated the o2's..but dont quote me on it.
you should find provisions for those plugs in 89+ car though
---------- Post added at 11:44 AM ---------- Previous post was at 11:38 AM ----------
let me rephrase that... the year doesnt matter, those plugs hvae both sides... should be able to remove the ends and plug them up in the car. someone cut the "car side" of those two plugs,
Heat and air problem andyanderson489 1979-1995 Mustang GT 6 04-20-2012 01:11 AM
Aftermarket air filter 2011 GT500 (SVTPP) GT500_CW3 Shelby Mustang 12 03-30-2012 06:00 AM
Buddy of mine bought an 86 gt and it had no air filter. lilrafe87 1979-1995 Mustang GT 6 03-11-2012 05:46 AM
Cold air intake Joecrane88 2005-2010 V6 Mustang 12 03-10-2012 02:57 AM
Turbulent air flow with side window down Vanwall 2011-2014 Mustang GT 1 03-07-2012 04:46 PM
05:18 PM
