question:why does my 5.0L...... - Mustang Evolution
Old 03-12-2012, 05:25 PM   #1
JFF90LX's Avatar
why does my 5.0L run good for a little while, then runs like crap and eventually shuts off? when I first start it it runs good no problems but after like 10 minutes it starts to run rough and when you rev it up it sputers and when it comes back down to idle it almost dies and eventually will die? please help me
JFF90LX is offline   Reply With Quote
Old 03-12-2012, 06:18 PM   #2
do you have any codes? good tune up may help but might not solve. i would check your fuel pressure first. then follow the procedures in you service manual to check and or clean the following parts: iac, maf, and tps. then follow the correct procedure for setting idle.
---------- Post added at 07:14 PM ---------- Previous post was at 07:11 PM ----------
http://www.muscularmustangs.com/tps.php
---------- Post added at 07:15 PM ---------- Previous post was at 07:14 PM ----------
http://mustang.blogsome.com/2005/10/...le-adjustment/
---------- Post added at 07:16 PM ---------- Previous post was at 07:15 PM ----------
http://www.stangnet.com/mustang-foru...cklist.698148/
---------- Post added at 07:18 PM ---------- Previous post was at 07:16 PM ----------
All of these links can be found in the sticky section under "useful mustang information" plus a lot more useful stuff. After you've checked these let us know what u came up with and we will see what we can do.
Old 03-12-2012, 06:30 PM   #3
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
+1 sounds like the fuel pump is getting hot which means time for a new pump but check everything else that's been mentioned first
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 03-12-2012, 06:34 PM   #4
1995boss's Avatar
Re: question:why does my 5.0L......
Check fuel lines and filter and even the fuel pump.
1995boss is offline   Reply With Quote
Old 03-12-2012, 10:41 PM   #5
94GT inblockcam's Avatar
Hey im a new member ......i was thinling if it was a fuel problem wouldnt it happen from eng. start it s
94GT inblockcam is offline   Reply With Quote
Old 03-12-2012, 10:48 PM   #6
1995boss's Avatar
From the sound of it in my experience and understand. It sounds to be a fuel up pump. I'm not sure the question your asking? You should rephrase that question.
Old 03-12-2012, 10:52 PM   #7
Hey im a new member ......i was thinking if its not a fuel pressure prob.i would check the O2 sensor...see when the engine is cold the o2 isn used there is a consistant rich air fuel ratio sent to cyl. This is called open loop when the o2 heats up pcm goes into closed loop using it to adjust ur ratio accordingly if ur o2 sensor is sending a incorrect rich voltage signal causing the pcm to correct a rich condition that is not there and will cause it to lean ur fuel to much causing ur symptoms..volt meter should tell u
Old 03-13-2012, 05:06 AM   #8
Pete Jones
Well here's the instance I experienced a couple years ago. Startup just fine, ran like a scolded dog for the first 5-10 mins then if you tried to jab the throttle it would not go past 2 grand, ease into the gas it would rev as high as u wanted.
Put a fuel pressure gauge on it and when it would mess up, I was around 40psi at idle, jab the throttle and it would drop the pressure clear down to 10 pounds.
Turned out the fuel pump was clogged or something and was causing the pump to "burn up" and not supply enough pressure.
Changed it out, good as new.
90 LX hatchback
89 LX Notchback
Old 03-13-2012, 06:03 AM   #9
There you go, good example.
That can happen if the:
Pump is bad or failing
Pump filter sock is collapsing
You put your underwear on backwards
Fuel filter is clogged
Lines are kinked or damaged
Regulator is damaged or malfunctioning
Fuel injectors are clogged or stuck
Old 03-13-2012, 11:51 AM   #10
Elfman's Avatar
Hahahah i laughed so hard at the third line. Thanks for the advice and humor you bring us
Elfman is offline   Reply With Quote
Old 03-13-2012, 02:46 PM   #11
I was wondering if anyone would see it.
Note: I do stuff like that in real life too. You should see some of the looks I get.
Old 03-13-2012, 02:49 PM   #12
Elfman's Avatar
Hahaha i like skimmed through it and was like, wait a min, and then i seen it and could stop laughing
Old 03-13-2012, 04:28 PM   #13
JFF90LX's Avatar
I changed the pump and filter after it started doing this and it didn't change anything
Old 03-13-2012, 04:41 PM   #14
Pete Jones
There any way you can upload a video of what it's doing?
90 LX hatchback
89 LX Notchback
Old 03-13-2012, 04:47 PM   #15
If you fuel pressure is set correctly, then I would start looking closer at the fuel injectors.
Old 03-13-2012, 07:09 PM   #16
JFF90LX's Avatar
eventually I've got it apart right now
Old 03-15-2012, 10:21 AM   #17
98RedGT's Avatar
Its prolly a cooling issue, does it start back up right after? Check your water pump.
ROOM FOR IMPROVEMENT
98RedGT is offline   Reply With Quote
Plastic Dip my Hood 06Ghost 2005-2010 Mustang GT 19 03-17-2012 05:19 PM
strut question fox87 1979-1995 Mustang GT 20 03-13-2012 08:40 AM
gt40 question????? fordracing63857 1979-1995 Mustang GT 10 03-12-2012 10:39 PM
Help Me Spend My Tax Return jjsg09 1996-2004 Mustang GT 11 03-12-2012 05:07 PM
02:11 AM
