Engine shops? - Mustang Evolution
Old 03-12-2012, 06:42 PM   #1
WhiteCobra94's Avatar
Engine shops?
Hey guys i just stripped my motor down to a bare block, It's a stock iron block but I want to hold on to it for now , around what price will it cost or a machine shop check it out and see if it can be saved , test it hone and bore it ?
Old 03-12-2012, 08:23 PM   #2
Re: Engine shops?
Probably whatever their shop minimum is to check it out.
I wouldn't hone or bore it until you have the pistons you will use in it.
That way the bore clearance can be set exactly instead of ballpark.
Old 03-13-2012, 05:19 AM   #3
Taxman's Avatar
I dropped my block off yesterday, to my neighbor (  ) shouldn't be no more then 2 or 3 hundred at the very very most. If your block is clean all they have to do is mic it an check for warp/cracks...
Taxman is offline   Reply With Quote
Old 03-13-2012, 06:32 AM   #4
I'm gonna order .30 pistons , and have the block cleaned, checked, and assembled for a backup block
Old 03-13-2012, 08:18 AM   #5
Taxman's Avatar
Did you check the cylinders? .30 may be to small... Or you may not even need .30
---------- Post added at 08:18 AM ---------- Previous post was at 08:17 AM ----------
An you need to check the top middle an bottom or every cylinder. While you have apart check the line bore also.
Old 03-13-2012, 08:24 AM   #6
Yea I'll check it out , now the rods and crank look brand new lol but there 18 years old,
Old 03-13-2012, 09:08 AM   #7
Taxman's Avatar
Once I talk to my machinist I'll let you know exactly but you can machine your crank journals so that they spin at a slower speed resulting in less stress/ wear on you mains...
I'll be talking to him in the next couple days....
If your going to build it you might as well do it right ya know..
Old 03-13-2012, 09:15 AM   #8
O definitely , do it right the first time !!!
Old 03-13-2012, 02:03 PM   #9
Re: Engine shops?
That's impossible.
RPM is RPM regardless of the diameter.
Have it micro-polished, make sure the bearing journals are all properly radiused and the oiling holes properly chamfered.
If the crank is worth it you can also have it knife edged and lightened so it spins easier and faster.
Old 03-13-2012, 02:57 PM   #10
Ok sweet, I'm not in a rush to
Get it done I just finished my new motor and actually headed to the shop now to take some new pics, I hope Friday it'll be done !!
Old 03-13-2012, 02:59 PM   #11
Re: Engine shops?
Can't wait to see you get it done and see how it performs.
Engine restoration Emachina Classic Mustangs 11 04-04-2012 10:24 AM
Engine shaking at idle and driving stangin Pre-2005 V6 Mustang 18 03-22-2012 02:46 PM
engine block color, valve covers and others questions lemons95 Pre-2005 V6 Mustang 3 03-13-2012 08:37 AM
service engine soon light znpzmustang Pre-2005 V6 Mustang 3 03-12-2012 12:44 PM
new engine? shadow commando Pre-2005 V6 Mustang 20 03-04-2012 12:25 AM
12:44 AM
