mustang wont run long - Mustang Evolution
Old 03-13-2012, 04:33 PM   #1
1995 mustang gt will start now but wont run very long
95 black vert is offline   Reply With Quote
Old 03-13-2012, 09:27 PM   #2
Re: mustang wont run long
Make sure you are getting fuel.
Check pump, pressure and fuel filter.
Old 03-15-2012, 07:04 PM   #3
I think I found problem (fuel pump) only 20 lbs
Old 03-15-2012, 07:11 PM   #4
Filibuster
Yeah it should never drop below 30!..pump is no good or the filter could be clogged too...or even that little sock thingy on the pump could be all gooie!..
XXSTEVEO66 is offline   Reply With Quote
Old 03-15-2012, 07:19 PM   #5
+1 doesnt hurt to make sure before dropping the tank.
Old 03-28-2012, 04:17 PM   #6
where and what is the epc
Old 03-28-2012, 04:51 PM   #7
93slowstang's Avatar
Epc is electronic pressure control. Do believe it's for your transmission.
Old 03-28-2012, 05:11 PM   #8
+1
Old 03-28-2012, 07:38 PM   #9
Do I have to remove tranny to fix (pulled code 624)
Old 03-30-2012, 08:55 PM   #10
does the epc effect the way the tranny shifts? Tranny is slipping
Old 03-30-2012, 08:59 PM   #11
95v686gt's Avatar
Yes it does. Sends a signal to the ecu about the pressure inside the transmission.
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 03-30-2012, 09:27 PM   #12
Thanks for answering that 95v686gt.
Sorry I missed your inquiries 95 black vert.
Old 03-30-2012, 09:33 PM   #13
95v686gt's Avatar
Eh I try
Old 04-01-2012, 11:54 AM   #14
Got trans pan off is the epc on drivers side,pass,front or back?
Old 04-01-2012, 12:18 PM   #15
Not sure, just try to match up the location as shown in the diagram above.
Old 04-06-2012, 02:56 PM   #16
will a c5 work in my 95 gt
Old 04-06-2012, 03:50 PM   #17
Not sure. What is it out of?
Old 04-06-2012, 06:11 PM   #18
it is out of a 1995 thunderbird behind a 302
Old 04-06-2012, 08:30 PM   #19
I was wrong its an aod but will it work in my 95 gt? It does not have the eletronic hook ups
Old 04-06-2012, 11:13 PM   #20
It will fit, but I'm not sure of the effect, if any, it might have on your ECU.
Old 04-10-2012, 05:02 PM   #21
got aod put in stang. does it matter which way the tranny lines go (can the top be the bottom)?
Old 04-10-2012, 05:33 PM   #22
If you cleaned out the cooler then it should not matter.
If you did not and you hook it up backwards there is a chance you might backwash some debris into your transmission.
I would advise cleaning the cooler in any transmission rebuild or replacement.
Old 04-10-2012, 08:21 PM   #23
95v686gt's Avatar
I'd recommend a standalone tranny cooler. Keeps the fluid temperature down alot better than the cooler in the radiator.
Old 04-11-2012, 01:20 PM   #24
Yes, but I would keep the factory cooler in the radiator as it is way more efficient at removing heat due the the liquid heat transfer that occurs. I add my air to liquid coolers after the radiator cooler to further cool the transmission fluid after the radiator cooler has removed the bulk of the heat.
Old 04-11-2012, 07:22 PM   #25
95v686gt's Avatar
+100 agreed. Great minds think alike
Old 04-13-2012, 05:30 PM   #26
drove mustang 2day and ran it hard but tranny fluid was shooting out of vent on top of tranny when i parked it whats wrong?
Old 04-13-2012, 07:22 PM   #27
Could u have put too much fluid in it. I know they will do that if the over full and I'm not for sure what else will do that
Robbie94gt is offline   Reply With Quote
Old 04-13-2012, 08:51 PM   #28
+1 Too much fluid or a clogged filter can do that.
Also if it got very hot it may be boiling the fluid, which is not a good thing.
Old 04-27-2012, 11:00 AM   #29
aod tranny will not shift while driving stuck in drive and when started automactically goes into drive but when engine not running will go into P R N D. Does this have anything to do with the tv cable
Old 04-27-2012, 08:52 PM   #30
I would suspect your shifter cable is stuck.
Old 04-29-2012, 09:37 AM   #31
Was the shifting problem there since the transmission swap, or just started?
All41 is offline   Reply With Quote
Old 04-30-2012, 02:16 PM   #32
since the swap
---------- Post added at 02:16 PM ---------- Previous post was at 02:12 PM ----------
problem was present after swap
Useful Mustang Information - READ THIS FIRST! Trojan Horse 1979-1995 Mustang GT 24 11-19-2012 09:54 PM
Mustang #3 (SOLD) :: 2004 Ford Mustang GT SNK3BTE04 Member Garages 0 03-13-2012 10:58 AM
Mustang #1 (SOLD) :: 1988 Ford Mustang 5.0 LX SNK3BTE04 Member Garages 0 03-13-2012 10:57 AM
"Bessy" Mustang #2 (SOLD) :: 1994 Ford Mustang GT 5.0 SNK3BTE04 Member Garages 0 03-13-2012 10:48 AM
Mustang #4 (SOLD) :: 2004 Ford Mustang GT 5 Speed SNK3BTE04 Member Garages 0 03-13-2012 10:41 AM
04:29 PM
