Problem..please post - Mustang Evolution
Old 03-14-2012, 06:02 PM   #1
93_347foxbody's Avatar
Alright well i've posted a few times about a short in my taillight, now correct me if i may be wrong bc im trying to figure out the problem. The previous owner said there was a short in the taillight, he said it was in the wire harness. I tested it and its fine. So i thought it may be something with the fuses. I didnt get to test em yet but the one has a red wire tapped off it and when the fuse accidently touched another fuse spot the fuel pump started to pump. Also there is power all the time from a yellow wire coming off the solenoid. And i just read one of the wires coming off that go to the fuel pump. Another thing is that when i turn my key backwards the fuel pump starts pumping, also is there is wires tapped off my taillights going to the fuel pump, now im going to guess and say maybe the guy messed up with the wiring on the holly fuel pump and thats whats causing the taillights not to stay on. Correct me if theres supposed to be wires tapped off the taillights and/or the fuse, and if the pump is supposed to start pumping when i turn my key backwards.
---------- Post added at 07:02 PM ---------- Previous post was at 07:01 PM ----------
thank you to everyone who read this im trying to figure this out and its confusing lol
93_347foxbody is offline   Reply With Quote
Old 03-14-2012, 06:21 PM   #2
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Sounds like you got a basket case. The pump should not be kicking on if you turn the key back to accessory
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 03-14-2012, 06:22 PM   #3
Re: Problem..please post
whats a basket case?
Old 03-14-2012, 06:27 PM   #4
Pete Jones
Meaning someone's had their fingers in there before you messing with stuff which in turn makes it a headache for you or someone else to figure out what they messed up heh
90 LX hatchback
89 LX Notchback
Old 03-14-2012, 06:35 PM   #5
ohhh yeah the guy b4 me messed with alota stuff some good some bad but do u kno if theres supposed to be 2 wires coming off the taillight wire harness for the fuel pump? im not sure he had wires twisted with wires on the harness
Old 03-14-2012, 06:37 PM   #6
Pete Jones
I don't believe so, thereis a inertia switch back there somewhere if I remember right(fuel cut off in case of accident) can you snap a pic of the wires in question and post them?
90 LX hatchback
89 LX Notchback
Old 03-14-2012, 07:15 PM   #7
im not at my dads house now so i cant get a pic till tomorrow after school but yeah theres the cut off switch and thats what these 2 wires are going to but there twisted together with ones coming off the switch
---------- Post added at 08:15 PM ---------- Previous post was at 07:49 PM ----------
And i just remembered this when my keys turned backwards the and the fuel pumps pumping the fuel gauge says 7punds of pressure..but.. when i turn the key forward the pressure goes down to zero so this may also be why i was having problmes starting the car...either i just figured it out with out knowing anything bout cars or im going nuts lol
Old 03-14-2012, 08:18 PM   #8
Get you a manual with wiring diagrams and start tracing wires.Whenever someone starts hacking on wiring it's a PITA the track down.
You can use the manual to check wire color codes and see what should or should not be connected.
Old 03-14-2012, 08:36 PM   #9
im going to get one but the wire harness for the taillights isnt the same as the other 93s i think bc the previous owner got a harness outa a junkyard out of a 92 I believe but theyre not the same, and when i went to a&a to get reverse bulbs they didnt fit in the harness thats in my car now but it fit in that other one, i kno the wires are probably the same colors but the guy b4 messed around alot with the wiring im finding out :/
Official Post your picture thread Brent Pictures and Videos 3582 10-07-2017 11:11 PM
post clips of your exhaust sound 1quick4.6 Pictures and Videos 37 04-02-2012 11:34 PM
Post brake pad install help silvr002001 1996-2004 Mustang GT 7 03-12-2012 07:26 PM
09:02 AM
