94 gt running very hot - Mustang Evolution
Old 03-16-2012, 02:38 PM   #1
Cstyle1's Avatar
I have no mods just yet. But when im driving my car heats up really bad. Not like over heating... heating up... But like sittin by a fireplace type of heat. The heat that my car generates is crazy. I checked the radiator and over flow tank and they are both full of water. The radiator hoses are hot to the touch. I live in CA bay area and its rainy weather right now. My temp guage never goes even half way to normal. Whats the problem?
Cstyle1 is offline   Reply With Quote
Old 03-16-2012, 02:47 PM   #2
I really hope u mean anti freeze water is not a really good idea
tbonestang is offline   Reply With Quote
Old 03-16-2012, 02:56 PM   #3
Cstyle1's Avatar
Mostly water. Should I flush it and fill with anti-freeze? How would I be able to tell if my thermostat wasnt working right without tearing it all apart?
Old 03-16-2012, 03:08 PM   #4
Ur in sunny Cali and ur using mostly water bad . Empty and fill with the right combo. And as for the thermo does the upper rad hose always stay hard.
Old 03-16-2012, 03:45 PM   #5
1995boss's Avatar
I would say look at your water outlet gasket. It's where the upper radiator connects to the manifold. Mine was all old and hard replaced it and it reduced my temp. By a significant amount.
1995boss is offline   Reply With Quote
Old 03-16-2012, 04:03 PM   #6
Yes he's correct and make sure u have the right mix of anti and water
Old 03-16-2012, 04:32 PM   #7
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
Flushing your radiator and lines could reveal a possible clog in your cooling system.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 03-16-2012, 05:50 PM   #8
Cstyle1's Avatar
Thx. Its pouring outside rit now so cant do a whole lot. It looks a little coroded around the water neck. So ill replace it as soon as the weather lets up. What temp thermastat does everyone recomend?
---------- Post added at 04:50 PM ---------- Previous post was at 04:48 PM ----------
The upper radiator hose is never really hard. Probably need to replace that also
Old 03-16-2012, 06:57 PM   #9
Re: 94 gt running very hot
Use the factory recommended temperature thermostat.
You can get them in high flow models if needed or desired.
Old 03-16-2012, 07:43 PM   #10
^ this ^
lots of people think that using a colder thermosat is better.but all it does is make it take longer for your vehicle to warm up.but once your enginge temp is past the thermostats rating it will just stay open letting the coolant continuous cycle through the radiator.
Old 03-17-2012, 02:09 AM   #11
Cstyle1's Avatar
Thx for all the help
Plastidipping GT emblems & trunk badge ghst 2005-2010 Mustang GT 11 04-02-2012 06:13 AM
Wheels/Tires Possibly for sale and GT OEM Strut Tower avengnd Mustang Parts for Sale and Wanted 7 03-28-2012 08:07 AM
04 GT for $800 FORDGT14 1996-2004 Mustang GT 13 03-16-2012 10:53 PM
GT/CS Wheels 08Mustang Mustang Wheels & Tires 15 03-15-2012 11:10 PM
2012 GT Spare jonmar 2011-2014 Mustang GT 11 03-15-2012 02:20 PM
04:34 PM
