New to Mustangs and Site - Mustang Evolution
Old 03-16-2012, 10:02 PM   #1
Nicks86GT's Avatar
I just bought an 1986 Mustang GT Convertible, looking to use it as a daily cruiser and weekend drag... Its a 5 Speed, I am looking for any tips or advice.
Nicks86GT is offline   Reply With Quote
Old 03-16-2012, 10:28 PM   #2
Whitestang93's Avatar
Welcome! Do you have any pictures?
Whitestang93 is offline   Reply With Quote
Old 03-17-2012, 12:20 AM   #3
deadsp0t's Avatar
Welcome to the site!
That's unimpressive
Old 03-17-2012, 01:56 AM   #4
93slowstang's Avatar
Welcome.
Old 03-17-2012, 02:38 AM   #5
It's not me, it's you.
primer2tone's Avatar
Welcome!
Old 03-17-2012, 08:36 AM   #6
89Saleen141's Avatar
Re: New to Mustangs and Site
Are you planning on keeping it carbed? What has been done to it so far?
89Saleen141 is offline   Reply With Quote
Old 03-17-2012, 09:07 AM   #7
Welcome and look at the sticky threads in this forum for tips and advice on modding.
I will leave this thread here since you asked for tips and advice, but when you have time go to our Introduction forum and introduce yourself there too.
Old 03-17-2012, 09:10 AM   #8
Welcome
Old 03-17-2012, 12:01 PM   #9
Welcome, from another new guy! There is a huge number of things you can do, but if you want it to perform much better, you may wanna consider switching from speed density to Mass Air induction. This will allow you like a hundred cam choices, few of which can be used on your stock engine.
Otherwise, you can still do several things, like rear gears(3.73 or 3.55 would be good), exhaust front to rear, air filter(or complete CAI), pulleys, alternator, head porting, intake, battery relocation, torque box upgrade, full suspension, etc.
The heads can be great, but I'd look for aluminum instead, if for no other reason, to shave weight.
An 86 didn't have a carburetor when new. It got Sequential Electronic Fuel Injection(SEFI).
All41 is offline   Reply With Quote
Old 03-20-2012, 07:18 AM   #10
Nicks86GT's Avatar
Sorry to get back at everyone but I have been having cooling issue, leaks, hoses and now the heater core is leaking... Anyway I can bypass or just remove the heater core??
Old 03-20-2012, 07:25 AM   #11
Yes, just connect the two heater hose connections on the engine with a short piece of hose.
Old 03-20-2012, 07:42 AM   #12
You could also get caps from your local parts store... 3/4 and/or 5/8 should do.
Old 03-20-2012, 08:13 AM   #13
Nicks86GT's Avatar
Sweet thanks
Old 03-20-2012, 08:48 AM   #14
Ok, you got me again, and be easy, it's still early morning for me.
Caps or pipe plugs?
I wasn't sure if the connections were still threaded as they used to be or pressed in as most are nowadays, which is why I suggested using a hose?
Old 03-20-2012, 09:35 PM   #15
Caps or pipe plugs?
If it's the same as the 87-93, and I would think it is, there are two different size pipes on the core itself, so I'm kinda remembering 2 different pipes along the intake. These are non-threaded and caps are fairly common at parts stores... but you have to find a parts guy/gal who's been around awhile or it may be like chasing wild hogs. I've gotten them from NAPA, O'reilly, AutoZone and Advance in the past.
1 word of caution on the caps: They deteriorate more quickly than hose(probably because there's no actual flow) even though they are rubber. Hose IS the better option impo, but caps make it look cleaner.
For the hose, there's a chance you'll need to get a connector to step down from 3/4 to 5/8, and need two small amounts of hose... Again, I haven't done this stuff in quite some time... I just think those are the sizes. They may both be one or the other instead(if so, probably 5/8). I am thoroughly convinced, however, it's at least 1 of those 2 sizes.
Old 03-20-2012, 10:13 PM   #16
Ok, I know what you are talking about now.
I think those caps are actually meant for vacuum.
I had an issue with my 86 when I first bought it spraying coolant.
I traced it to one of those types of caps.
I was talking about doing away with the tubes and connecting or capping/plugging it off at the front of the engine.
Old 03-21-2012, 04:57 PM   #17
Nicks86GT's Avatar
Ok, sounds good, I was thinking that I could use a steel or aluminum cap. Never seen a rubber cap.
Old 03-21-2012, 07:47 PM   #18
See! They deteriorate... Most often, vacuum probably is the use. At that size though... ya really think they're meant just for vacuum? Idonno... I know something else they'll work for...
Oh, yeah... If he's removing the coolant pipes altogether, that's a great idea and I'd expect those to be screwed in, but haven't looked in ages.
You can buy a 1/2" (or whichever size you need) pipe thread plug, I'd think. A little teflon tape and blam...
Old 03-21-2012, 09:03 PM   #19
Yeah, some big trucks and large equipment use them.
They won't work for me for that purpose. They're too big.
To keep or delete plastidip Jayjay 2005-2010 Mustang GT 16 03-23-2012 05:28 PM
Picked up a new 2012 Mustang SpectorV General Mustang Discussion 15 03-22-2012 09:59 AM
Bought and installed the quarter window louver but... 08MustanGT 2005-2010 Mustang GT 4 03-17-2012 11:20 PM
New Vossen Wheels Msoler 2011-2014 Mustang GT 21 03-17-2012 09:47 PM
What are we going to do when gas gets to $20.00 a gallon 1995boss The Bar 12 03-16-2012 04:41 PM
11:05 AM
