302 break in - Mustang Evolution
Old 03-16-2012, 11:13 PM   #1
302 break in
A buddy of mine rebuilt his 302 n were wondering how we should break .it in properly.....below is a list of the stuff that he's done to it.....
fordracing63857 is offline   Reply With Quote
Old 03-17-2012, 12:19 AM   #2
I would just not get crazy on the throttle for 1-3k miles.you may want to change the oil after the first 500 miles to get any leftover shavings out.but someone will chime in to give u a better answer.
Also I would get that beast professionaly tuned.its probably not 100% required but will help big time.dyno tune is best but if u can't do that.American muscle (site sponsor) can probably supply a preburnt chip setup for your mods.they also have a forum discount.
Also I just built my motor pretty much identical..030 over,tfs heads,1.72 rr,b303.I am running weiand stealth intake and 670 carb though.I was wondering if u guys get it dynod or take it to the track ,can u update here with results?
Old 03-17-2012, 12:33 AM   #3
deadsp0t's Avatar
Only thing I'd add to this is I'd wait at least 2k miles and get a magnetic drain plug!
Sounds like a sweet set up! Would love to see some pics!
That's unimpressive
Old 03-17-2012, 08:47 AM   #4
Re: 302 break in
There are many theories and not much real proof in the realm of "How to properly break in a new engine".
Here's some advice from an engine builder.
Ford Strokers Break In Procedure
Myself, I operate the engine easily for the first 500 miles using break in oil and letting it go through several heating and cooling cycles and RPM ranges without any WOT runs. I am also a a magnet fanatic. I run one on the bottoms of the oil pan sumps, use magnetic drain plugs, and use one on the filter. Those metal particles are much less harmful stuck to one of the magnetized areas than circulating through your engine.
I change the break in oil out at the 500 miles and replace it with whatever I have decided to use. From there on I drive it like I intended for it to be driven. For the first 2-3 oil changes I change at 3000 mile intervals. After that I either change the oil when it appears dirty or at 5000 miles. With some synthetic oils this can be extended to as much as 15000 miles, but that's scary long to me.
When I say "appears dirty" I mean when it turns black from use and contamination. Sometimes this will happen sooner than the scheduled oil change interval because of driving habits or situations. City driving in stop and go traffic and short trips will contaminate the oil much quicker than highway driving. Therefore I will change the oil sooner than the scheduled interval.
Who"s actually drunk in the bar? 1995boss The Bar 21 04-28-2012 05:12 AM
80 degrees in Iowa!!! 89white GT 1979-1995 Mustang GT 18 03-19-2012 10:11 PM
I know this is in the wrong spot 32vNomad SVT Mustang 0 03-16-2012 03:17 PM
Finally putting in 8.8 l2plagears Pre-2005 V6 Mustang 10 03-16-2012 03:15 PM
emissions light in dash mustang07 2005-2010 Mustang GT 1 03-15-2012 07:12 PM
05:45 AM
