Engine Miss - Mustang Evolution
Old 03-17-2012, 07:01 PM   #1
Taxman's Avatar
I have a very bad miss, i even think I might be firing on 4... I will be pulling my plugs tomorrow to see if I can find any indication of no fire..... But where so I start to problem solve this issue??
Taxman is offline   Reply With Quote
Old 03-17-2012, 08:54 PM   #2
Re: Engine Miss
Verify that you have fire to each plug and that the wires are not crossfiring to each other.
When the plug wire insulation starts to break down the wire can start to leak energy.
The easiest way to see this is to start it up in the dark and look for flashes or a corona around the plug wires.
The hard way is to feel for it if you can stand the pain.
Once you have verified that your ignition system is working, then start checking your fuel system.
Old 03-18-2012, 06:37 AM   #3
Taxman's Avatar
Corona? Is this a typo? If not please explain
Old 03-18-2012, 07:43 AM   #4
Taxman's Avatar
Doesn't that look a little lean?
Old 03-18-2012, 07:49 AM   #5
Re: Engine Miss
Corona = Glow
Attachment 44111
Actually it looks fairly normal.
Lean would be white and you'd possibly have blister like spots on the insulator and ground strap.
Old 03-18-2012, 07:50 AM   #6
Taxman's Avatar
I think new wires wouldn't hurt
Old 03-18-2012, 07:53 AM   #7
Taxman's Avatar
Corona = Glow
I'm going get new wires and plugs. It can't hurt... Btw the miss is around 1500-3000 rpms..... After 3 it actually runs pretty good.... :/
Old 03-18-2012, 07:58 AM   #8
Re: Engine Miss
Attachment 44112
Whoa! There's at least part of the problem.
Good idea, It'll run better when it isn't leaking voltage.
It may clear up a bit at higher RPMs as the ignition pulses are coming a lot faster and more voltage is able to get past the bad spot to the plug.
Old 03-19-2012, 08:16 AM   #9
Taxman's Avatar
Well I fixed the miss... It's not near as bad as it was, but I found a deeper secret about my engine....
One of my plugs has oil on it... I'm 95% sure it's the valves leaking a little bc I never see it smoke.... (sigh)
Old 03-19-2012, 08:38 AM   #10
Re: Engine Miss
Could very well be the valve guide seals.
They get hardened and brittle over the years, eventually breaking apart.
Someone driving behind you might see a puff of smoke when you accelerate hard.
That's an indication that the seals have failed.
Old 03-19-2012, 11:05 AM   #11
Taxman's Avatar
If I ran it like it is till the mid. Summer you think it would be a problem?
I plan on having my new motor by then.... An I check the oil often.....
Old 03-19-2012, 12:20 PM   #12
Re: Engine Miss
I don't think so. You'll just lose a bit of oil and since you check it frequently you should be ok.
The one problem that may occur depending on how much oil goes through it, is contamination of the O2 sensors.
Old 03-19-2012, 12:45 PM   #13
Taxman's Avatar
Man your good... When I did my exhaust (just recently) I changed them both... I didn't look at em.. Just left them in bc I new they were old...
Old 03-19-2012, 12:55 PM   #14
Re: Engine Miss
Thanks I try.
Just be aware and keep an eye on it and if you notice the engine heating up a bit (lean) or you smell raw fuel (rich) you might check them out.
Old 03-19-2012, 02:11 PM   #15
Taxman's Avatar
I forgot to tell my story yesterday...
So after I Did my spark plugs an wires, I took her round town.... So I'm on my way back to my house an decide to pass up my road an hit a straight away... Well I did one pass an turned around... Then my car died... I checked under the hood an everything seemed good, so I figured it was my fuel filter... After the tow home an a Lil inspection... I was outta gas lol
Old 03-19-2012, 02:19 PM   #16
Haha. You got bit by the MT bug.gets the bests of us.
Old 03-19-2012, 02:33 PM   #17
Taxman's Avatar
Lol.
check engine light 2002Gt 1996-2004 Mustang GT 48 03-31-2012 07:11 PM
MAC ProChamber & V6 Engine robb15033 Pre-2005 V6 Mustang 8 03-24-2012 11:55 PM
Need help! My stang has a miss! Fatboy scott 1996-2004 Mustang GT 7 03-20-2012 06:24 PM
Engine shaking at start up 813floridaracin Pre-2005 V6 Mustang 5 03-14-2012 08:54 PM
Engine shops? WhiteCobra94 1979-1995 Mustang GT 10 03-13-2012 02:59 PM
01:37 AM
