electrical question - Mustang Evolution
Old 03-18-2012, 02:15 PM   #1
93_347foxbody's Avatar
electrical question
I know these pictures are really bad but does anybody know what these wires under the driver seat lead to? And possibly what they're for. They come from behind the kicker pannel and down and turn under the seat and back up through somewhere near the radio
93_347foxbody is offline   Reply With Quote
Old 03-18-2012, 03:25 PM   #2
94GT inblockcam's Avatar
R u sure u lead the same wit ur finger not ur eye and so it comes from under column inside kick panel goes under the carpet directly to the underside of ur driver seat and then goes back up to near ur head unit is towards where it started
94GT inblockcam is offline   Reply With Quote
Old 03-18-2012, 03:40 PM   #3
Re: electrical question
yes but someone hooked a toggle switch up to the yellow wire in it, my step dad said it could be for the reverse light, something about the tranny in it might not turn the lights on or something
Old 03-18-2012, 03:53 PM   #4
Could be a gear position senor usually by ur shifter..it controls ur reverse lt circuit when u hit R...
---------- Post added at 01:50 PM ---------- Previous post was at 01:49 PM ----------
5spd or auto
---------- Post added at 01:53 PM ---------- Previous post was at 01:50 PM ----------
Let me get wire colors on the connector
Old 03-18-2012, 04:18 PM   #5
5spd or auto
5speed and i just left my house so i cant get the colors now unless you can see em in the picture wait do u mean the wires on the toggle switch? bc if so theyre yellow
---------- Post added at 06:18 PM ---------- Previous post was at 05:56 PM ----------
another electrical question for anyone that reads this, is it bad it theres 2 fuses going into fuse #11 bc the previous owner has what i believe is the fuel pump tapped off it
Old 03-18-2012, 04:28 PM   #6
Is the wire tan and light green.cause I just wired up my factory fuel pump relay to work with my carb setup and I had to modify a tan light green wire under the seat.
---------- Post added at 05:28 PM ---------- Previous post was at 05:26 PM ----------
Some cars had wires under the seat that went to factory power seats also.
Old 03-18-2012, 04:31 PM   #7
its red ill post a few pics bc its really confusing on how he wired up the holly pump lemme send em to my computer from my phone ill post em in a few minutes
Old 03-18-2012, 04:43 PM   #8
the brown wire comes off the fuel pump along the passenger door side under the carpet then twists with 2 reds and goes into some black thing on the frame the one red goes to that fuse and the other goes to the solenoid
Old 03-18-2012, 04:45 PM   #9
well it twists with this orange one then goes to the solenoid
Old 03-18-2012, 04:47 PM   #10
It's probably a kill switch to the f pump the right?
Old 03-18-2012, 04:50 PM   #11
lol na their two separate things think i just asked that question under this post bc theyre both electrical and i didnt think it was necessary to post a new thread lol but i think the killswitch is for my reverse lights bc my step dad said something about some trannys dont turn on the reverse lights so they might have put that in to turn em on and off
Old 03-18-2012, 10:06 PM   #12
Well about the post earlier I thought u had auto so its differ
---------- Post added at 07:39 PM ---------- Previous post was at 07:30 PM ----------
Manual u would have a clutch pos. Sensor and a neutral safety switch....
---------- Post added at 07:59 PM ---------- Previous post was at 07:39 PM ----------
Do we know wat fuse 11 is for ...wen u say twisted means wires r ran together for a total of 2red wires and 1 brwn or does it go from 1 brwn splits to 2 reds ....
---------- Post added at 08:06 PM ---------- Previous post was at 07:59 PM ----------
If splits....so one red goes to fuse 11 and the other goes to starter sol. To the B+ or the smaller ign wire
Old 03-19-2012, 12:23 PM   #13
I figured out the fuel pump problem but fuse 11 is for the radio. And thanks for helpin me out a bit but I prob. won't be do8ing muchb with the car bc my dad just passed away and I was hoping wed work on it but idk enough to do much with it so I'm thinkin bout sellin it
Old 03-19-2012, 12:29 PM   #14
I'm really sorry to hear that and I extend to you my sympathy.
We will be here to help you if you decide to keep it.
Old 03-19-2012, 12:55 PM   #15
I am sorry to hear that. if you need anything we are here for you.
I don't know your dad or anything but I'm betting he would want you to keep it.we can help you out with anything you need.
Old 03-25-2012, 08:33 PM   #16
Sorry bro thay say that the pain slowly fades but the love will be there forever.... Bro u keep the mustang I will send u a extra after market part for ur ride
Old 03-25-2012, 08:57 PM   #17
im gonna keep it but its gonna be hard bc i still have to go to my dads and work on it to get it running to get it out of there but i cant take any after market parts id feel bad
Old 03-25-2012, 09:00 PM   #18
Sure you can. It's a hand up, not a hand out.
What do you need?
Old 03-25-2012, 09:03 PM   #19
What do you need?
na i cant take anything but thanks for offering it means a lot the only thing i need is help figuring out why my tail lights wont stay on but yet the brake lights work and all
Old 03-25-2012, 09:21 PM   #20
The tail lights are on a different wire from the brake lights.
Maybe it has been broken or cut?
Is the tail light ground intact?
Old 03-25-2012, 09:31 PM   #21
i checked most of the wires in the wire harness and they were good and the grounds are good the previous owner got a used harness out of another 93 mustang in a junk yard, and the 2 harnesses arent the same like the bulbs arent the same so im thinking about just taking out the whole harness and putting the other one in bc a&a gave me the stock bulbs for a 93 and they match the other harness
Old 03-25-2012, 09:34 PM   #22
That would be best and it would make future troubleshooting a lot easier if it is needed.
Old 03-25-2012, 09:37 PM   #23
yeah i might take a look at it this week i dont know yet i have to get my starter on first so i can drive it over to my moms and finish everything there
exhaust question Big Johnson 2005-2010 Mustang GT 13 03-19-2012 08:46 AM
stock heads question asap please 87blackonblack 1979-1995 Mustang GT 3 03-17-2012 10:23 PM
misfire question sean03gt 1996-2004 Mustang GT 28 03-17-2012 03:47 PM
Resonator question Rolltide 2011-2014 Mustang GT 6 03-15-2012 07:48 PM
A question of a swap Blackedout Pre-2005 V6 Mustang 0 03-15-2012 10:31 AM
11:17 AM
