Starting problem- I'm baffled - Mustang Evolution
Old 03-18-2012, 04:18 PM   #1
jhagan1980's Avatar
Went to start my car a few weeks ago after driving for about 10mins. I tried to start it and nothing happened and when I say nothing I mean no lights, gauges, and no click. Turned off the ignition and then a series of clicks began from my dash between the door and my steering wheel. Dad took me home and I got my old battery and put it in and it fired right up. So afterward I have put new battery, ignition lock(mine was busted), and a pa performance starter. Thought the problem was fixed but it just did it again 30 mins ago. Undid both sides of the battery and waited 30secs-1 and hooked back up. Needless to say it fired right up. What in the wide world of sports could be causing this? Computer?
jhagan1980 is offline   Reply With Quote
Old 03-18-2012, 04:24 PM   #2
Sounds to me like your cables are bad.
Old 03-18-2012, 04:45 PM   #3
jhagan1980's Avatar
I put new cable ends on but they are the compression type that you screw on
Old 03-18-2012, 05:05 PM   #4
Re: Starting problem- I'm baffled
Sounds like a problem with some type of power relay under the dash.
Time to drag out the diagrams and start tracing the system from the key switch out.
Old 03-18-2012, 05:13 PM   #5
jhagan1980's Avatar
Not real good at that
Old 03-18-2012, 05:45 PM   #6
Ok, I ran through a couple of diagrams I have and I didn't see any power relays in the ignition/starting system under the dash.
Are you sure the clicks didn't come from under the hood?
A starter solenoid will do that when it is getting low voltage.
More than likely dreamstang is correct and you have some bad cables.
Those screw on ends are known for bad connection problems.
Replace the cables with new HD cables or fab your own with some welding cable and solder on brass ends.
I'd completely replace the cables you have instead of trying to put different or new ends on them as the wire can get corroded inside them over time and reduce their current carrying capacity. Then you can be sure they are not the culprit.
Old 03-18-2012, 06:16 PM   #7
jhagan1980's Avatar
Could bad cables cause it to do absolutely nothing?
Old 03-18-2012, 06:23 PM   #8
If you lost connection then yes.
you could wiggle the cables around while someone else tryed to start is.but that way won't tell you for sure.especially if it was not contacting when it ran last and let the battery drain.the best thing would be to do as Trojan suggests and change them.but like a said wiggling the cables may help verify but not for sure.
Old 03-18-2012, 06:37 PM   #9
Definitely could cause it to do absolutely nothing.I replaced my cables like I said above with 1/0 welding cable (the wires are finer and it carries more current) and soldered on brass battery cable ends.
I have never had any further problems with them.
The 1/0 cable may be a bit of overkill, but I wanted to be sure that I have plenty of juice to all of my components, especially when I add the electric fan, water pump, MSD ignition, AFM PMS and any other electrical accessories.
Old 03-18-2012, 06:39 PM   #10
Camo1967Mustang's Avatar
Almost sounds like the problem I had a few days ago
There r 4 relays under the dash behind the fuse panel
My car didn't start n I heard clicking from under the steering wheel
Try changing one of them
Adrian
2001 Mustang
--AM CAI, BBK Headers, Dual exhaust, Billet grille, hood and side scoops, Sequential tail lights,
AM Headlight covers, Fog lights, Chin spoiler, H&R Lowering Springs, KYB Shocks and Struts
January 2012 StangAlley ROTM
Camo1967Mustang is offline   Reply With Quote
Old 03-18-2012, 06:40 PM   #11
jhagan1980's Avatar
The starter solenoid is out of the question right seeing how I just put a new starter in? Could the ignition switch cause this? I know it controls a lot of the electrical circuits.
Old 03-18-2012, 06:44 PM   #12
Yes it could.
The solenoid will still click like that with low voltage even if it is new.
Old 03-18-2012, 06:45 PM   #13
clark98gt's Avatar
My 84 had the same problem. I could drive it all day starting it up and everything then out of the blue you would turn the key and it would click once and all of the lights and everything would go out stone dead. Mine turned out to be a crappy ground. Just retrace your ground from your battery and the one from the block to the body and make sure they look good and secure.
1998 Gt- current progress
Engine back in car some reassembly required
clark98gt is offline   Reply With Quote
Old 03-18-2012, 06:52 PM   #14
jhagan1980's Avatar
Yes it could.
It did it once before new starter and has done it once after new starter.
---------- Post added at 12:52 AM ---------- Previous post was at 12:50 AM ----------
That is gonna be my next job. I did undo what I believe was a ground from the firewall to the hood when I got my cobra r hood because it had nowhere to attach it.
Old 03-18-2012, 07:50 PM   #15
clark98gt's Avatar
I dont think the ground to the hood would be an issue. Its the other ones that would cause issues.
Old 03-18-2012, 07:58 PM   #16
jhagan1980's Avatar
Figured but I thought I'd say it just incase.
Old 03-18-2012, 08:03 PM   #17
the grounds you should check are battery to engine,and battery to chassis.
Old 03-18-2012, 08:13 PM   #18
jhagan1980's Avatar
I've never changed cables before but I'm guessing if I change out the cables then I'll mess with the ground connections right?
Old 03-18-2012, 08:16 PM   #19
just make sure when you change the ground cable( the battery -) just make sure that where you bolt it is clean and free of paint and you should be ok.
Old 03-18-2012, 08:27 PM   #20
jhagan1980's Avatar
Thanks for all the help guys.
Old 03-18-2012, 08:29 PM   #21
no problem.hopefully that fixxes it.if not on to the next solution.
Old 03-18-2012, 09:03 PM   #22
Not all of them.
I would add (if you don't already have them) a ground from the engine to the firewall and to the front frame rail to ensure you have good grounds for your ECU and any other interior components grounded to the body or frame.
Rev from idle problem CoyoteXII 2011-2014 Mustang GT 11 03-27-2012 07:50 PM
Big Problem Camo1967Mustang Pre-2005 V6 Mustang 18 03-23-2012 11:01 PM
CD player problem StackeStang 1996-2004 Mustang GT 7 03-17-2012 08:48 PM
MIL eliminators problem 01mustang01 1996-2004 Mustang GT 9 03-16-2012 09:33 PM
Problem? :( 2Greeny7 Pre-2005 V6 Mustang 11 03-15-2012 07:26 AM
11:30 PM
