broke a sparkplug - Mustang Evolution
Old 03-18-2012, 07:05 PM   #1
stang4life1's Avatar
broke a sparkplug
I broke a spark plug off in the head on 4 hole by the fire wall any ideas on how to get it out it broke off after the nut on the spark plug and no room to easy out it
stang4life1 is offline   Reply With Quote
Old 03-18-2012, 07:10 PM   #2
is there anything sticking off to grab onto? if there is they make sockets that are made especially for rounded bolts.i would soak it in some penetrating oil now and let it soak so whatever route you go it will be easier.
if you cant get it out the next step may be to pull the head but hopefuly you get it first.
good luck
Old 03-18-2012, 07:13 PM   #3
Re: broke a sparkplug
That's not good.
If the ceramic broke apart and fell into the cylinder you will need to remove the head and vacuum it all out of there. Otherwise it's going to score up your cylinder and ruin your engine.
If there is enough sticking out and you can get to it to weld, you can weld a large bolt into it and use that to remove it?
Old 03-18-2012, 07:15 PM   #4
I got the ceramic piece out and theres very little metal sticking out and it was so thin when i tried to vice grip it out and i just did a head job on it i accidently put an old spark plug back into that hole and it broke off when i retried taking it out
Old 03-18-2012, 07:19 PM   #5
maybe you can take a pic for us so we can see what it looks like?
Old 03-18-2012, 07:21 PM   #6
Got it figured out with an easy out and a torch for some heat and a 3/8s wrench and got it out
Broke it some more, pic of busted oil pan inside... Project Pony Pre-2005 V6 Mustang 11 03-22-2012 06:31 PM
AGGH! I Broke it! Project Pony Pre-2005 V6 Mustang 5 03-06-2012 07:54 PM
Im broke 01StangGt 1996-2004 Mustang GT 1 02-23-2012 11:50 AM
My Side Mirror Broke Off and Now I Need Advice Regarding Replacement JimHyde 1996-2004 Mustang GT 3 12-03-2011 08:16 PM
fuel filter hose broke!!!!!!! 88fox 1979-1995 Mustang GT 20 11-25-2011 12:11 AM
12:28 AM
