electrical issue? - Mustang Evolution
Old 03-20-2012, 03:42 PM   #1
Slvr01GT's Avatar
electrical issue?
my 89 gt is having an issue with the battery losing its charge, Its a new battery and a new alternator but my battery wont hold its charge longer than a day, I cant find the problem, any help would be greatly appreciated.
Slvr01GT is offline   Reply With Quote
Old 03-20-2012, 03:53 PM   #2
shawnpbigelow's Avatar
Check all the wires on your alternator. Make sire they are hooked up right.
---------- Post added at 05:53 PM ---------- Previous post was at 05:45 PM ----------
shawnpbigelow is offline   Reply With Quote
Old 03-20-2012, 03:55 PM   #3
Slvr01GT's Avatar
Re: electrical issue?
i'll try that, hopefully its something im overlooking.
Old 03-20-2012, 04:49 PM   #4
E
Old 03-20-2012, 06:29 PM   #5
Slvr01GT's Avatar
the thing is that it was the same issue before i bought the new alternator and battery. the wires are fine on the alternator.
Old 03-20-2012, 08:27 PM   #6
sounds like you may have a short somewhere. it wouldnt hurt to double check your battery cause just recently i read a thread were a guy got 3 bad batterys in a row from autozone.he finally upgraded to a different brand it was fine.
Old 03-20-2012, 10:18 PM   #7
Make sure you don't have an under hood or glove box or map light that's staying on.
Check the fuel pump relay too and make sure the contacts haven't welded themselves together so the fuel pump stays on all the time.
Old 03-22-2012, 06:29 PM   #8
Filibuster
Id disconnect the battery and check it with a voltmeter then hook it back up and check it again(eng off of course) to see if there is a draw on it..then that should tell you if there is a short..
I had this problem as well.turned out the diodes fried on the voltage regulator causing the short..
XXSTEVEO66 is offline   Reply With Quote
Old 03-22-2012, 08:24 PM   #9
SSC182's Avatar
If you have a DMM you need to do a parasitic draw test that will tell you if somthing is running while the car is off
SSC182 is offline   Reply With Quote
Old 03-26-2012, 03:33 PM   #10
Slvr01GT's Avatar
Thanks a lot guys, I really appreciate it.
electrical question 93_347foxbody 1979-1995 Mustang GT 22 03-25-2012 09:37 PM
2004 GT Convertible top issue randyj68 1996-2004 Mustang GT 5 03-19-2012 09:22 PM
T-5 Tranny issue Klinton 1979-1995 Mustang GT 8 03-13-2012 08:11 AM
electrical fans Jettin Stang 1979-1995 Mustang GT 28 03-12-2012 03:26 PM
Shaker 500 issue Svtbmac215 Mustang Audio & Video 2 03-11-2012 12:27 PM
11:35 PM
