1998 tranny in fox body - Mustang Evolution
Old 12-14-2007, 08:26 PM   #1
Does anyone know what you need to put a tranny from 1998 mustang in a 1993 mustang?
pocket99 is offline   Reply With Quote
Old 12-14-2007, 09:33 PM   #2
Re: 1998 tranny in fox body
the tranny from the 98 is a T-45 so it wont bolt up right unless they make a bellhousing to adapt it to match a 5.0L engine. The normal tranny in the 93 is a t-5.
Old 12-17-2007, 09:23 AM   #3
Titus Wadicus
svtlx's Avatar
also, the speedo in a fox is mechanical/cable...and i "think" a t-45 is electric for the speedo.....i think so anyway.
Old 12-25-2007, 06:53 PM   #4
YsOffcr's Avatar
Send a message via AIM to YsOffcr
FYI the speedo is mechanical until 99 where it went to electronic.
YsOffcr is offline   Reply With Quote
Old 12-27-2007, 02:24 PM   #5
SilentNoise's Avatar
Send a message via MSN to SilentNoise
Or you can get a T-5 out of a later model 6-banger. They were running T-5s into the 99+ years I believe.
.... I'm not 100% on whether or not things will be a direct match though. I think the output shaft was different, but don't quote me on that.
Wolf Pack Car Club - Domestic V8 Performance Club (Edmonton, AB, Canada)
"If the automobile had followed the same development cycle as the computer, a Rolls-Royce would today cost $100, get a million miles per gallon, and explode once a year, killing everyone inside." -Robert X. Cringely
SilentNoise is offline   Reply With Quote
Old 12-29-2007, 04:53 PM   #6
I found out that it is a tranny from a v6. Is the output shaft the only thing that has to be changed?
Old 12-30-2007, 09:22 AM   #7
Titus Wadicus
svtlx's Avatar
HMMM, i know dat the output shaft has to be changed when using a fox body 4cyl. t-5 to put on a v-8, but i know guys that run it as is. i'm run'n one of those over priced racing aod's so i probably have no business in this commenting, as soon as i got my coupe i yanked out the t-5.
Old 12-30-2007, 11:12 PM   #8
silverstangboy's Avatar
the input shaft will have to be changed as well... the trans for a v6 has a longer bellhousing. I have heard of guys taking them to a machinest and turning the input shaft down.
93 mustang notch
~450hp 331 stroker - Sold
Old 12-31-2007, 10:37 AM   #9
I have heard the opp. as well that the tranny bolts right up... so I would research to double check. I dont see ford changing out the input shaft when they dont have to.
Old 12-31-2007, 01:02 PM   #10
rocknbronco's Avatar
I'm gonna say no..... Unless you spend more money on machining than it would cost for the T5....
rocknbronco is offline   Reply With Quote
Old 01-12-2008, 03:53 PM   #11
spec. I believe it depends on wether or not the T-5 is going into a fox or not. I'm not 100% as i've never wanted to run a v-6 tranny..
93 mustang notch
Old 01-15-2008, 06:00 AM   #12
The thing is the later model V6's made more horsepower than the Fox 5.0L's. I wouldn't worry about it not holding up.
Old 01-15-2008, 07:48 AM   #13
the 99+ T-5 is supposed to be stronger than any 5.0L (stock) T-5 so they say.
Old 01-18-2008, 09:34 PM   #14
:srugs: I could really care less, my TKO does the trick.
93 mustang notch
Old 01-19-2008, 08:51 AM   #15
bbunt302's Avatar
193 > 225.
More importantly...
225 > 300.
Got it.
Scary stuff.
Old 05-08-2008, 02:09 PM   #16
i was wondering if it it possible for me to a 4 cyl 5 spd to a 302 i am just trying to put this together temporaily i inderstand that it may not last long but the 302 that i am putting in it for the time being is nothing special at all it's just a stock 302 with a 2 barrel carb so it really doesn't have much power at all but i would like to just drive the car for now while i am building the other motor......
daveycarpenter is offline   Reply With Quote
fox body
poor fox body hottcobra Pictures and Videos 8 05-16-2009 09:17 PM
Another Fox body newbie 74H1E New Member Introductions & Greetings 4 05-09-2009 08:02 AM
Looking at a 1989 5.0 Fox Body sebian 1979-1995 Mustang GT 16 06-01-2007 09:37 PM
For all the Fox Body people... Cajun JungleBoy Pictures and Videos 8 02-20-2007 02:29 PM
Fox Body for sale Silver1988stang Mustangs for Sale and Wanted 1 07-31-2004 11:30 AM
04:52 PM
