Heads question - Mustang Evolution
Old 03-21-2012, 10:39 AM   #1
jhagan1980's Avatar
Heads question
Got "permission" to buy a set of heads but not sure which ones I would get the most hp from. I'm still not sure I want to drop $1000+ on heads but I'd figure I'd get some info. Currently I have 266hp and 364tq, I'm wanting at least 300hp to the wheels. Could I accomplish this with a good set of heads? Also what could I get out of my old gt40 heads if I get new ones and sell the 40's?
jhagan1980 is offline   Reply With Quote
Old 03-21-2012, 11:29 AM   #2
WhiteCobra94's Avatar
What's done to the car ?
Old 03-21-2012, 11:59 AM   #3
jhagan1980's Avatar
I'll name what I can off the top of my head, motor or other wise.
Long tube headers
O/r x pipe
Flowmasters
65mm tb
C&l CAI
Egr delete
3:73 gears
Upper&lower control arms
31 spline axles
Old 03-21-2012, 12:01 PM   #4
Bballing0416's Avatar
Trick flow twisted wedge heads
Bballing0416 is offline   Reply With Quote
Old 03-21-2012, 12:04 PM   #5
jwhayne0001's Avatar
Next tax time I'm going for getting trick flows HCI kit supposed to promise 320 to the wheels but it's 2200 bucks
jwhayne0001 is offline   Reply With Quote
Old 03-21-2012, 12:07 PM   #6
Did you dyno in at 266hp , ? Head wise edelbrock performer heads start around $1,200 , trick flow and AFR are $1300-$2000, edelbrock makes E-Street heads for sbf for $980
---------- Post added at 01:07 PM ---------- Previous post was at 01:05 PM ----------
It's worth it tho!!!!
Old 03-21-2012, 12:09 PM   #7
jhagan1980's Avatar
Yes that was on the Dyno and I also had the SCT chip installed and tuned at that time. Forgot to list the chip up top.
Old 03-21-2012, 12:13 PM   #8
Well check edelbrock heads out they'll be $980-$1300, I hear guys using ProComp heads for $800 ish but I don't know much about them
Old 03-21-2012, 12:25 PM   #9
jhagan1980's Avatar
If I'm gonna buy heads I want the best bang for my buck. If I have to spend $100-200 more for better heads than so be it.
Old 03-21-2012, 12:30 PM   #10
Good !! I just finished my first build and went with edelbrock , you also have to watch what size heads you go with cause you will have to send your short block to a machine shop and have your pistons flycut...... Check out Edelbrock performer heads #60379 there are made for stock pistons, $1,200
Old 03-21-2012, 12:34 PM   #11
I have the trickflow heads and they are amazing.there are 1200 on American muscle but you can use your forum discount which will save around 70$.but you will have to buy pushrods to run those heads which you can get for under 100$.
Then the Afr are great.but you would have to run the 165 s unless you have knotched pistons.and the ages are a little more pricey.
Then of course like already mentioned edelbrock makes good heads also.
Old 03-21-2012, 12:45 PM   #12
jhagan1980's Avatar
Is 300hp possible with just doing heads on my car?[COLOR="Silver"]
Old 03-21-2012, 12:48 PM   #13
Heads , cam, and intake
Old 03-21-2012, 03:21 PM   #14
1995boss's Avatar
If I were you do things right the first time around. You could put heads on but then you put more pressure on the bottom end. This could result in blow seals, leaking (nothing you want to happen). If I were you I would just want to do it right.
1995boss is offline   Reply With Quote
Old 03-21-2012, 09:26 PM   #15
Re: Heads question
Read an article some time back (MM&FF I think.) where they bolted a set of AFR 165 heads to a mild 5.0 and gained 100 HP. If you can get the same results that should get you close to your goal.
Old 03-21-2012, 09:58 PM   #16
jhagan1980's Avatar
That should get me way past my goal
Question about tuner Venomouz831 AmericanMuscle 3 03-28-2012 02:52 PM
electrical question 93_347foxbody 1979-1995 Mustang GT 22 03-25-2012 09:37 PM
Jr Windsor heads saleen5.0 1979-1995 Mustang GT 8 03-21-2012 07:41 PM
tfs twisted wedge 192 heads saleen5.0 1979-1995 Mustang GT 2 03-20-2012 02:19 PM
this is probably a dumb question medicespo 2011-2014 Mustang GT 7 03-20-2012 01:01 AM
07:36 PM
