Question about Brakes - Mustang Evolution
Old 03-22-2012, 01:29 PM   #1
88gtCc's Avatar
When I depress the brake pedal really fast it makes a "Whoosh" noise. I had assumed maybe that its normal, since its been like that since day one and my brakes are still strong enough to easily lock up the tires. Today, my brake light comes on due to low fluid (most likely need new pads but dont think thats the main factor in loosing the fluid). Im not seeing any visable leaks anywhere...just wondering if anyone has any clues as to what might be going on?
88gtCc is offline   Reply With Quote
Old 03-22-2012, 03:30 PM   #2
stampde's Avatar
Re: Question about Brakes
front brake hoses or rear wheel cylinders , witch you really cant see unless you pop of the wheels and drums
2011 GT Auto
Old 03-22-2012, 04:24 PM   #3
88gtCc's Avatar
Thanks! Ill be sure to check that. I have zero idea how drum brakes operate; cant be that hard tho
Old 03-22-2012, 04:30 PM   #4
If there are no visible signs of leaking fluid, then it is likely that your fluid level is low just because the pads are worn down. As they wear it takes more and more fluid volume to press the pads hard enough into the drums and rotors to provide adequate stopping power. You really should check your brake fluid level more often as it could end up being a life or death matter for your and others.
The "whoosh" noise is caused by the air (on the other side of the vacuum diaphragm) in your brake booster being exhausted quickly. It is normal and nothing to worry about.
Old 03-23-2012, 10:28 PM   #5
Taxman's Avatar
The woosh sound sounds like your booster could be going out. (been there do that lol)
Is it possible for the fluid to go into the booster? About every 3 months I add a can of fluid to my system bc it's leaking, an I can not see it at all, not on my hoses, breaks, the ground.... Unless some one is stealing it :/
It's on a c1500 hehe..
Taxman is offline   Reply With Quote
Old 03-24-2012, 07:47 AM   #6
Probably a small leak on one or more of your wheel cylinders.
Heat from the brakes my be boiling off or evaporating the fluid before it leaks out enough to drip and be visible.
Thinking about retiring the roush Rapinator126 Roush Mustang 14 05-26-2014 08:07 AM
Suspension question RVAStang05 2005-2010 Mustang GT 3 03-27-2012 02:50 PM
sct tunner question tc x 4 2005-2010 Mustang GT 4 03-22-2012 03:47 PM
Heads question jhagan1980 1979-1995 Mustang GT 15 03-21-2012 10:58 PM
Thinking about a s281 wing. Yes or No? 1995boss 1979-1995 Mustang GT 20 03-21-2012 07:23 AM
05:46 PM
