Fuel pumps - Mustang Evolution
Old 03-22-2012, 01:11 PM   #1
NeedSomeMods's Avatar
Fuel pumps
What's a good size? I know with injectors they can't be too big; does the same principle apply to pumps?
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 03-22-2012, 01:27 PM   #2
04machazblue's Avatar
Need mod
Info
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 03-22-2012, 01:51 PM   #3
Cai, tb, professional products intake, e303, cobra heads, shortie headers, o/r h, flows.
2000 V6 - RIP
The '94 -
Old 03-22-2012, 02:34 PM   #4
WhiteCobra94's Avatar
Go with a 190 or 255, your fuel pump size doesn't matter because your fuel pressure regulator will control that!!!
---------- Post added at 03:34 PM ---------- Previous post was at 03:32 PM ----------
Of your going to put a power adder then go with 255 if not 190 is plenty
Old 03-22-2012, 02:59 PM   #5
I won't have a power adder for a while, it's my DD. so, can you have "too big" of a fuel pump? The price difference between the sizes is minimal so I'm just curious..
2000 V6 - RIP
The '94 -
Old 03-22-2012, 03:03 PM   #6
No you can't have too big of a fuel pump, your fuel pressure regulator controls the amount of fuel going Into the engine ! I would suggest a new fuel pressure regulator along with the new fuel pump
Old 03-22-2012, 03:40 PM   #7
Okay great thanks for the info.
2000 V6 - RIP
The '94 -
Old 03-22-2012, 05:09 PM   #8
Re: Fuel pumps
The problem with a to large a pump is the unnecessary circulation of the gasoline. Too much re-circulation can heat up the gasoline which can cut performance and cause cavitation in the pump. The heat causes the gasoline to expand, meaning you can't get as much of it into the cylinder as when it is cold and the cavitation can introduce air bubbles into the fuel system.
Old 03-22-2012, 05:23 PM   #9
I can see that. I'll just stick with stock for now until the time comes for 24# injectors, MAF, fuel pressure regulator, and dyno tune. Probably go with the 190lph pump.
Sound good?
2000 V6 - RIP
The '94 -
Old 03-22-2012, 05:35 PM   #10
190 should be good now and future.
Old 03-22-2012, 05:37 PM   #11
Re: Fuel pumps
+1 That should do the trick.
Walbro 255lph Fuel Pump CodyNelson Mustang Parts for Sale and Wanted 3 03-27-2012 04:55 PM
fuel problem kcaito23 2005-2010 Mustang GT 8 03-22-2012 10:40 PM
Fuel cell 19foxbodylx93 2.3 Mustang 0 03-20-2012 10:33 AM
Fuel economy GrabberBlue5.0 2011-2014 Mustang GT 37 03-18-2012 07:21 PM
Fuel Filter change... DaYanks4Ev Pre-2005 V6 Mustang 8 03-17-2012 08:22 PM
07:05 AM
