dr's or slicks - Mustang Evolution
Old 03-22-2012, 06:43 PM   #1
mystang50's Avatar
dr's or slicks
95 auto (stock converter) full bolt on gears, drviesaht, and other misc., also a 100 shot every now and then
Don't know witch way to go...I have rims for dr's, 17x9
But no rims if I do slicks, Jus want some suggestions I have $$ now and ready for the track
---------- Post added at 06:43 PM ---------- Previous post was at 06:42 PM ----------
And of I have to do slicks...what size rims tires and all that
Old 03-22-2012, 07:28 PM   #2
captain78's Avatar
All up to you. I have 17x9s with 255/40-17 but as for track I'm goin with either 15s or 16s just match the height of your tire now and get that height slick on whatever wheels you gonna run
captain78 is offline   Reply With Quote
Old 03-22-2012, 07:31 PM   #3
If your only gonna use them for the track then I would go slicks
Old 03-22-2012, 09:52 PM   #4
mystang50's Avatar
Yes only for the track
Old 03-23-2012, 07:13 AM   #5
Re: dr's or slicks
Check out the new MT ET Streets.
Old 03-23-2012, 10:59 AM   #6
Stang.racr's Avatar
I'd go with some 275/4017 nitto 555r. They are a pretty good all around drag radial. You would need a driveshaft loop and upper and lower control arms to help strengthen the chassis. I'd stay with a drag radial. Doing 100 plus in a bias slick is not a fun ride!
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 03-23-2012, 11:05 AM   #7
mystang50's Avatar
I have sve upper and lowers...would I have to have driveshaft loop??
---------- Post added at 11:05 AM ---------- Previous post was at 11:05 AM ----------
What size rims would I need for these??
Old 03-23-2012, 11:08 AM   #8
Re: dr's or slicks
You should always have a driveshaft loop if you are going drag racing.
If the driveshaft fails at the front where it is attached to the transmission it can drop down and dig in, pole vaulting your car or come up through the floorboards. Believe me, you do not want it flailing around in the cockpit when you are in there.
Sorry, I reread that and now I know.
You'll have to see what sizes are available.
They show a - ET Street Radial Pro P275/60R15
Being new they may have limited sizes for a while, but they will usually make them in 15" diameter to start out with as that is one of the most popular sizes.
Old 03-23-2012, 11:09 AM   #9
Stang.racr's Avatar
I've run 275s on a 17/9 rim. You could run 315s on a 17/10.5. You need a driveshaft loop. They are cheap and easy to install. I believe they are mandatory for 12.99 and faster cars anyway. SOME tracks will check and since you have that much power and are about ready to double your traction then I'd surly spend that money. A driveshaft breaking at the tranny and coming through the floor board wouldn't be cool lol, another thing the nitto 555r don't have as much of a bite as nt05 or mt et street radials but they last longer and they are more street friendly.
Old 03-25-2012, 09:55 AM   #10
mystang50's Avatar
Well I will only be using on track, which ones should I go with??
Old 03-25-2012, 11:48 AM   #11
Re: dr's or slicks
For track use only I'd go with a slick.
Let the manufacturer help you choose a size and compound.
To be honest I've never really seen the sense in using "Street" drag radials for most people.
They end up driving around with them on just to be a lot of the time and they wear out pretty quickly doing street duty.
Here's a couple of links with information you may find useful.
Tips on Drag Slicks
Tire Technology
Old 03-25-2012, 07:11 PM   #12
captain78's Avatar
The reason for drag radials is because most tracks when running street class require you to use dot tires and you get the traction of a slick with a drag radial that you won't get from regular street tires.
Old 03-25-2012, 07:42 PM   #13
Re: dr's or slicks
Yeah, my post wasn't very clear was it.
I know that if the class requires DOT tires they are your best option, but given a free choice and if not required by class I would always choose the slicks instead.
Wrinkle walls wind up a bit when you launch and give you a bit of a slingshot effect during take off and who doesn't enjoy a bit of slingshot now and then.
Old 03-25-2012, 08:05 PM   #14
captain78's Avatar
Lol I didn't realize that was you who posted that ^^ lol
Old 03-25-2012, 08:34 PM   #15
Re: dr's or slicks
That doesn't matter, you caught me not making myself very clear fair and square.
Old 03-26-2012, 09:02 AM   #16
mystang50's Avatar
Yall ain't making this easy for me...lmao
What would benefit me best?? I'm afraid to go with slicks cuz I think that I might bog down on launch cuz ill be launching off idle...so I'm asking what would be best for me??
Old 03-26-2012, 09:13 AM   #17
Re: dr's or slicks
Sorry bout that.
Launching off idle almost any inexpensive drag radial should do.
Why off idle?
Old 03-26-2012, 09:22 AM   #18
mystang50's Avatar
Sorry bout that.
Why off idle?
K thanx...Auto, stock converter. I might try foot break too 1500 Jus to try
Old 03-26-2012, 09:28 AM   #19
Re: dr's or slicks
Foot brake it and see at what RPM it breaks the back tires loose.
When launching bring it up to a couple of hundred RPM below that number.
When the lights drop, on the last yellow (.500 tree), release the brake and hammer it.
Old 03-26-2012, 09:42 AM   #20
mystang50's Avatar
Yeah I was gonna try it...on my street tires my 315's i can hold at 1500 Im sure it will be completly diff on dr's, but gonna try it
---------- Post added at 10:42 AM ---------- Previous post was at 10:41 AM ----------
What dr's should I go with?? For 17x9's any suggestions??
Old 03-26-2012, 09:53 AM   #21
Re: dr's or slicks
Size is up to you and whatever you wish to use or what will work for your car.
I always like my drag racing tires to have a bit of sidewall so I always go with 15" rims.
If you won't over power the 17x9's they should work just fine for your car.
Old 03-26-2012, 09:59 AM   #22
mystang50's Avatar
Allrighty. Any tire u recommend...or any one eles u know or on here recommend 1??
Old 03-26-2012, 10:04 AM   #23
Re: dr's or slicks
I favor the ET Streets over the others, but the Nittos or other DOT drag radials would probably work ok too.
Old 03-26-2012, 12:25 PM   #24
mystang50's Avatar
Witch nittos?? So I can compare
Old 03-26-2012, 01:21 PM   #25
Re: dr's or slicks
NT05R - Would probably be my choice for your car.
But the NT555R would work as well.
Should I get a V6 or V8 Mustang? Thefitnesskid 2011-2014 V6 Mustang 95 07-27-2016 05:14 PM
Xmission issue or clutch adjustment needed Nicks86GT 1979-1995 Mustang GT 10 04-06-2012 10:40 AM
Procharger or vortec sc for 11'5.0 MT 3.73? JG5.0 2011-2014 Mustang GT 20 03-27-2012 06:24 PM
To be staggered or not staggered!? Gobabygo67 1996-2004 Mustang GT 50 03-25-2012 01:10 PM
Are These Loudmouth 1s or 2s? TheJigShow 1996-2004 Mustang GT 2 03-21-2012 10:26 PM
02:23 PM
