solenoid wire & tail light question - Mustang Evolution
Old 03-22-2012, 10:20 PM   #1
93_347foxbody's Avatar
anyone know what the yellow wire coming off the solenoid is bc its drawing power at all times, and what else could it be if my tail lights dont stay on but the brake lights work and the reverse lights and all work and i tested the harness and that fine too
93_347foxbody is offline   Reply With Quote
Old 03-22-2012, 10:33 PM   #2
are you talking about your starter silinoid?the reason i ask is because alot of people tend to wire up many things off of it because it is a good 12 volt source thats easily accesible.
Old 03-22-2012, 10:35 PM   #3
Re: solenoid wire & tail light question
yeah the starter one and idk the yellow wire seems stock bc it goes with a bunch of other wires in this tube through the firewall
---------- Post added at 11:35 PM ---------- Previous post was at 11:35 PM ----------
**starter solenoid
Old 03-22-2012, 10:39 PM   #4
if its hooked to the same terminal as the positive battery cable,then ou will always read 12 volts.are you sure its actually drawing power?or are you getting reading off the battery?i would check the battery with a meter. and wait a few hours and check it again (without using anything power) and see if the voltage on the battery changed.
Old 03-22-2012, 10:43 PM   #5
i feel somewhat like n idiot bc i didnt even think of which terminalk it was on but non of the other wires on it are drawing power and my battery will be completely drained if i leave it hooked up and idk if theres a short in the tail lights somewhere or something the previous owner messed alot with the electrical and im trying to figure it out
Old 03-22-2012, 10:46 PM   #6
you may have to pull of the tubing and trace the wires.ill check out my schematic,but yourmprobably gonna have to follow it.
Old 03-22-2012, 10:51 PM   #7
thats what i didnt wanna do :/ lol oh well
Old 03-22-2012, 10:58 PM   #8
Ok yellow is connected to battery +
Btw this schematic is for my 88 vert but should be similar.
Yellow splits to : fuel pump relay,ignition,rear window heat,and on my car goes to convertible something.
Old 03-22-2012, 10:59 PM   #9
Schematic
Old 03-22-2012, 11:07 PM   #10
Schematic
thanks ill look into this alot more on sunday
Old 03-22-2012, 11:10 PM   #11
no problem.the only thing im not sure about is if your 4 split ismdifferent since you dont have a vert.i looked at my car and the yellow wire on the silinoid splits about 10 inches away from the silinoid.if you only have 3 wires coming off the yellow then its probably the same.if you have 4 like on mine then either the 4th one goes to something else or goes to the same thing but is not used.
Old 03-22-2012, 11:40 PM   #12
well it should help for the most part it shouldnt be too too different unless my previous owner altered it
Suspension question RVAStang05 2005-2010 Mustang GT 3 03-27-2012 02:50 PM
Question about Brakes 88gtCc 1979-1995 Mustang GT 5 03-24-2012 07:47 AM
help brake warning light killrocker52 2011-2014 V6 Mustang 7 03-22-2012 11:19 PM
New TB and Plenum question imhooked 1996-2004 Mustang GT 5 03-22-2012 10:38 PM
Egr question? Wshewan 1996-2004 Mustang GT 0 03-22-2012 08:22 PM
08:51 PM
