BBK Strut Tower Brace, not fitting. - Mustang Evolution
Old 03-23-2012, 05:18 PM   #1
NeedSomeMods's Avatar
Well, I got my BBK Strut Tower Brace for '94-'95 Mustangs in yesterday, test fit, and doesn't clear the Professional Products intake manifold..
The part that extends from the towers towards the front of the car is about 1/4" too short in the middle, where the manifold sits. What to do now??
There's the Steeda Brace:
Steeda 555-5705 Steeda Strut Tower Braces
and the Maximum Motorsports Brace:
1994-95 Mustang GT & Cobra Strut Tower Brace [MMSTB-3] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
but I honestly don't see how those two would fit either..
I kind of had the idea of taking a stock 94-98 brace to a welding shop and have them modify it to fit. Any thoughts?
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 03-23-2012, 05:53 PM   #2
WhiteCobra94's Avatar
That's what I'm doing , taking my stock one and cutting and welding it then painting it gloss black
I was gonna get the edelbrock one for $180 but I'll try myself first
Old 03-23-2012, 06:42 PM   #3
Beav's Avatar
Re: BBK Strut Tower Brace, not fitting.
Make your own, take your time, paint it nice, be proud of it...
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 03-23-2012, 06:45 PM   #4
That's how my whole car is I did the whole interior , exterior , paint, and motor build, the only thing I'm doing is the actually swap!!!
---------- Post added at 07:45 PM ---------- Previous post was at 07:44 PM ----------
(the only thing I'm not doing is the actually swap)
Old 03-23-2012, 07:25 PM   #5
I'd love to, but I don't know the first thing about welding or have the equipment to do so.
2000 V6 - RIP
The '94 -
Old 03-23-2012, 08:29 PM   #6
jwhayne0001's Avatar
The one for the cobra from cj ponyparts fits raised intakes
jwhayne0001 is offline   Reply With Quote
Old 03-23-2012, 09:27 PM   #7
Well I'm in the same boat cause I'm just finishing my motor sway and I have new urethane motor mounts which make your motor sit 1/2-1 inch higher, I have a 1 inch intake spacer to clear my valve covers plus my intake sits up higher then stock!!
Old 03-23-2012, 11:15 PM   #8
I'm looking at their site now, not sure which one you're talking about. Link?
2000 V6 - RIP
The '94 -
Old 03-24-2012, 06:01 AM   #9
http://www.cjponyparts.com/bbk-strut...-1995/p/STB15/
It comes out and up to clear intakes
Old 03-24-2012, 06:02 AM   #10
Its a much more aggressive rise than the 2 you posted says it clears most engine mods
Old 03-24-2012, 12:14 PM   #11
That is the BBK brace I have, and it's not fitting...
2000 V6 - RIP
The '94 -
Old 03-24-2012, 12:53 PM   #12
Can't go much high with stock hood
Old 03-24-2012, 01:48 PM   #13
Just space the mounting points forward with some 1/4" steel or aluminum plate?
Old 03-24-2012, 02:17 PM   #14
Here's what it looks like. How would I space it to fit?
ID:	44795   Click image for larger version
2000 V6 - RIP
The '94 -
Old 03-24-2012, 03:42 PM   #15
Use spacers at the firewall and front of the strut tower mounts to move the brace forwards.
Old 03-24-2012, 06:14 PM   #16
It looks like I'll need some 1/2" thick aluminum with holes drilled for all three points to get it perfect. I guess I'm going to a machine shop on Monday?
2000 V6 - RIP
The '94 -
Old 03-24-2012, 06:24 PM   #17
im sure u could make them yourself.a machine shop would get pretty expensive.
---------- Post added at 07:24 PM ---------- Previous post was at 07:22 PM ----------
aluminum drills really easy.im not sure if they have it that thick but check home depot,menards,lowes and places like that .they may have some aluminum flat.
Old 03-24-2012, 06:49 PM   #18
at home depot. I think this should do the trick if I cut and stack pieces until it's perfect.
2000 V6 - RIP
The '94 -
Old 03-24-2012, 06:50 PM   #19
1/8" thick, 2" wide, 36" long
2000 V6 - RIP
The '94 -
Old 03-24-2012, 06:51 PM   #20
that should work.
Old 03-24-2012, 07:57 PM   #21
Hopefully going to tackle this tomorrow. Trying to think of what to do about the top holes for the strut towers. When I space it out for the side holes, there's just enough room for holes on the top, but I don't know if I should drill into the actual car like that...
2000 V6 - RIP
The '94 -
Old 03-24-2012, 08:07 PM   #22
As long as you don't hit anything vital it will be fine.
Or you could have a piece welded on to extend the top bracket.
Old 03-24-2012, 08:21 PM   #23
good idea.just remember if you weld it with hard wire it may be difficult to drill,but as thin as it is you not have a problem.i would use flux core wire.it will still be hard to drill but not as bad as a copper coated type.6010 welding rod or 6013 will be nice and esay to drill but will not look as pretty.but if you grind it down no one will ever know.
Old 03-24-2012, 09:25 PM   #24
yeah, you lost me at "flux core wire". Lol. I'm going to make the spacers for the sides of the strut towers and the firewall. If that's still not secure enough, I'll figure out what to do about the top.
2000 V6 - RIP
The '94 -
Old 03-25-2012, 05:30 AM   #25
Been working all night, and decided to stay up a little later to make the spacers. I want this brace on ASAP!!
Right now, it looks like I'll have 3/8" (3, 1/8" thick pieces) on the sides and 1/4" (2, 1/8" thick pieces) between the firewall mounts and brace. I have cut the pieces like so:
3 - 2"x2.5" for the passenger's side
3 - 2"x3" for the driver's side
2- 2"x9" for the firewall
Currently waiting for the battery for the drill to recharge. Have made 3 out of 13 holes so far..
2000 V6 - RIP
The '94 -
Old 03-25-2012, 06:52 AM   #26
Done. Ended up using 3 on driver's side, 1 on passenger side, 2 on firewall. I got it JUST far enough to where it won't rub with the engine running. Bolted in, torqued down, solid as a rock. I did not drill into the top of the strut towers, but if it loosens up any I'll have no choice.
Anyway, I was at my work's shop making the spacers so I got a pretty nice drive home.. With plenty of detours. There's this one road; surrounded by trees and filled with curves and turns. Then went to I-45, exited, took an underpass u-turn, went down and u-turned again; honestly I felt so much more in control of the car than before. Sooo happy with the money, time, and effort put into it. Absolutely worth it! Oh, and it looks cool too.
ID:	44838   Click image for larger version
ID:	44840   Click image for larger version
2000 V6 - RIP
The '94 -
Old 03-25-2012, 07:09 AM   #27
Sweet! Glad it worked out.
Old 03-25-2012, 07:13 AM   #28
Glad it worked out for ya I love mine can't really tell a handling difference but it looks good lol
Old 03-25-2012, 07:23 AM   #29
Have you always had one?
2000 V6 - RIP
The '94 -
Old 03-25-2012, 08:50 AM   #30
Owned my car for like 7 months then I put it on
Old 03-25-2012, 12:13 PM   #31
Idk man.
To me, it feels more stable.
2000 V6 - RIP
The '94 -
Old 03-25-2012, 02:22 PM   #32
Idk man.
The car should feel "tighter" and more responsive, since you have eliminated some of the flexing in the front end.
However, throughout my years on internet forums I have noticed that some will immediately notice the change and others may not notice anything at all.
Old 03-25-2012, 03:19 PM   #33
It was basically for looks for me not really out canyon carving or racing I did feel let down on the feeling I did expect it to feel tighter but oh we'll it looks good
Old 03-25-2012, 03:35 PM   #34
deadsp0t's Avatar
Does you car have sub-frame connectors? Seems like if you had those it would be harder to notice.
Needsomemods, pretty cool how you worked that out! Nice work!!
That's unimpressive
Old 03-25-2012, 05:04 PM   #35
No subframe connectors, yet
Its DEFINITELY not stock anymore lol...NEW PICS INSIDE!!! CodyNelson 1996-2004 Mustang GT 57 05-20-2012 12:57 PM
BBK CAI Grabber Blue 2005-2010 V6 Mustang 13 04-07-2012 06:55 PM
To be staggered or not staggered!? Gobabygo67 1996-2004 Mustang GT 50 03-25-2012 01:10 PM
Anyobe order the steeda spacer and not receive gaskets wit it? Watchawow07SGT 2005-2010 Mustang GT 13 03-21-2012 08:14 AM
BBK Chrome Tuned Length Shorty Headers 2004GT 1996-2004 Mustang GT 8 03-18-2012 11:59 PM
10:05 PM
