Transmission fluid help 95' gt manual - Mustang Evolution
Old 03-24-2012, 11:37 AM   #1
1995boss's Avatar
I look to see what transmission fluid I need to use. I hear automation and can be synthetic 80 to 90 weight. Also if I can use automatic tranny fluid can I use auto tranny fluid treatment?
1995boss is offline   Reply With Quote
Old 03-24-2012, 11:50 AM   #2
04machazblue's Avatar
Use dex/merc in it u don't need any additives. Just the fluid
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 03-24-2012, 11:51 AM   #3
Re: Transmission fluid help 95' gt manual
I'd go by what the book says or look up the numbers on your transmission tag to find out what is recommended.
Some use automatic transmission fluid and others use gear oil (75-90 wt.)
You never want to mix or confuse the two as it would result in the destruction of your transmission.
For manual transmissions that use the automatic trans fluid I have read that the best fluid to use is the GM Synchromesh fluid, but check that out for yourself before deciding to use it.
Old 03-24-2012, 06:59 PM   #4
93slowstang's Avatar
Mine said dex/merc when I got it delivered. Three qts I believe. The non world class t-5s use gear oil.
---------- Post added at 07:59 PM ---------- Previous post was at 07:56 PM ----------
Hmmm, I've read that gm synchromesh was actually bad for the wc t5. Never could understand how it would be bad though.
Old 03-24-2012, 07:02 PM   #5
It very well could be, I haven't ran across that yet, but who knows.
There is so much misinformation that at times it is hard to determine what is the truth.
I'd contact the manufacturer direct and find out were it me.
Old 03-25-2012, 02:33 PM   #6
91BlueMule's Avatar
I know the tko 500 we put in our 91 coupe needed gm synchromesh. Not quite sure about a t-5. I know its important to put the right fluid!
91BlueMule is offline   Reply With Quote
Need help with Hid kit Noerrors8 General Mustang Discussion 22 04-01-2012 11:24 AM
What radiator fluid should i use Blackedout Pre-2005 V6 Mustang 10 03-25-2012 07:09 AM
94 gt heater cor 94Fivepoint0 1979-1995 Mustang GT 1 03-24-2012 10:07 AM
Transmission and torque converter Rm360 1996-2004 Mustang GT 0 03-24-2012 09:40 AM
GT/CS Fog lights Ap0cLFC 2011-2014 Mustang GT 5 03-24-2012 09:05 AM
08:22 AM
