93 5.0 Cobra - Mustang Evolution
Old 03-26-2012, 01:42 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
93 5.0 Cobra
How can I tell if my 5.0 is a cobra engine. I was told its a 93 cobra motor fuel injection.
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 03-26-2012, 02:06 PM   #2
WhiteCobra94's Avatar
Is the car a 93 cobra or just the motor?
Old 03-26-2012, 02:11 PM   #3
88gtCc's Avatar
The upper intake manifold should be rather easy to ID, and Id guess the lower would be the same as the upper. The gt-40 heads are also rather easy to ID. Look on the sides of the heads, there should be "lines" that stick out. 2 lines is gt-40 and 3 is gt-40p...I think (Im sure someone will clarify if Im wrong). As far as the short block, I think they are all pretty much the same? To be sure if its a cobra short block, you'll need to find the serial numbers on the block itself. Hope that helps a little
88gtCc is offline   Reply With Quote
Old 03-26-2012, 02:29 PM   #4
slow281
sixpac's Avatar
Region: Nebraska
I think it's just the motor the car is found threw a restoration and we have no vin numbers but the motor was said to be a "cobra" motor.
---------- Post added at 02:29 PM ---------- Previous post was at 02:27 PM ----------
ware are those numbers located as the motor is in the car now. is it possible it's a cobra intake and not the full motor?
2001 GT - True Blue
Old 03-26-2012, 03:36 PM   #5
88gtCc's Avatar
Honestly, Im not 100% sure where the blocks serial numbers are located. My best guess is underneath...back behind the oil pan somewhere. Its entirely possible you have the gt-40 heads/intake only. As I said, aside from minor differences, I believe all (old) 5.0 short blocks are the same.
Old 03-26-2012, 04:14 PM   #6
wc3john's Avatar
Re: 93 5.0 Cobra
The shortblock cobra and the shortblock gt 5.0 is the same in 93 only, in the years before hand, the pistons are different. Cobras have different heads, intake, injectors and computer. The cam is the same however. GT-40 heads have 3 bars and if you pull the valve cover, it will say GT somewhere on the head underneath the cover. The roller-rockers should say crane as well as they are 1.7 rr's instead of factory stamped stell 1.6.
Take pics of the motor if you can
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 03-26-2012, 10:20 PM   #7
93slowstang's Avatar
+1, except the cam is completely different.
Old 03-27-2012, 07:28 AM   #8
slow281
sixpac's Avatar
Region: Nebraska
I will look as soon as I have time it's just hard to work on everything when I don't know exactly which engine it is. which ones the cobra gt-40 or gt-40p ???
---------- Post added at 07:28 AM ---------- Previous post was at 07:20 AM ----------
the problem is I'm also not sure if it is a 93 for sure. it's a good running engine tho I'm gonna tare into the head and see what there looking like. will the number on the block tell me whAt year it is or what car it came out of or anything ?? thanks for the help
2001 GT - True Blue
Old 03-27-2012, 07:56 AM   #9
5.slow's Avatar
Region: Delaware
[QUOTE="sixpac"]I will look as soon as I have time it's just hard to work on everything when I don't know exactly which engine it is. which ones the cobra gt-40 or gt-40p ???
The 93 cobra had gt40 heads. The gt40p heads come from explorers.
5.slow is offline   Reply With Quote
Old 03-27-2012, 10:55 AM   #10
Re: 93 5.0 Cobra
The differences are really negligible and there is no huge advantage to having a "Cobra" engine. Check for the differences as noted above.
The casting number on the block is behind the starter, but it will only tell you the year that that particular casting was put into production and it may not match the year of the car.
Basically if you have a Cobra engine, great, if not, it is no big deal and you can easily build it to have more power than a Cobra engine anyways.
Old 03-27-2012, 01:26 PM   #11
stampde's Avatar
Re: 93 5.0 Cobra
you do get GT40 heads , Cobra intake ,and crane (Cobra) 1.7 rockers ,so It is a +++ if it is a Cobra engine ...............
there's also a vin # stamped on the back of the block ,just behind the intake manifold on top where the bell housing bolts up ... if you can get it ,have a dealer run the vin ,see if it is the real deal ...
2011 GT Auto
Old 03-27-2012, 01:33 PM   #12
slow281
sixpac's Avatar
Region: Nebraska
ik that the intake is cobra for sure it ha the D code one the intake.
2001 GT - True Blue
Old 03-28-2012, 11:40 PM   #13
slow281
sixpac's Avatar
Region: Nebraska
I don't mean to sound dumb but what and ware exactly are the rockers? I'm used to working on newer stangs and broncos.
2001 GT - True Blue
Old 03-29-2012, 04:11 AM   #14
Picture of the rockers you should have.
UPDATE Drusmith's Cobra drusmith SVT Mustang 45 04-19-2012 11:05 PM
2.3 to 5.0 Musdoyurtang 2.3 Mustang 28 03-30-2012 08:40 AM
Procharger or vortec sc for 11'5.0 MT 3.73? JG5.0 2011-2014 Mustang GT 20 03-27-2012 06:24 PM
1989 5.0 auotmatic to t-5 swap Dkerk8 General Car Discussion 0 03-26-2012 08:44 AM
1997 cobra mustang hood Jerob 2011-2014 Mustang GT 8 03-25-2012 08:41 PM
04:46 PM
