Idle Control Valve - Mustang Evolution
Old 03-26-2012, 07:33 PM   #1
NickMac's Avatar
My 95 5.0 was idling a little ruff, I started by checking the air filter to see if it may be clogged. To my surprise the filter was twisted like a pretzel. I changed the filter and the Idle Control valve. Now the car is idling worse.... Also while in idle the lights are dimming in and out and the gauges are fluttering.... Please help
NickMac is offline   Reply With Quote
Old 03-26-2012, 07:54 PM   #2
Re: Idle Control Valve
Check your EGR valve and vacuum lines.
The lights may dim and gauges flutter if the idle goes to low.
Old 03-26-2012, 07:59 PM   #3
whats up bro.
im still thinking your UD pulleys may be causing some issues.but the experts will be here soon was it doing this when you first charged the battery?the reason i ask is maybe if you charge the battery again and it quits doing it for a while then you know you are having charging issues.also you can put a meter on the battery.you should get 12.5 volts not running and 14.4ish running.
---------- Post added at 08:59 PM ---------- Previous post was at 08:55 PM ----------
oh wait, the expert beat me to the punch.
Old 03-26-2012, 08:57 PM   #4
NickMac's Avatar
Well the car was running pretty good the last few weeks, there was just a slight idle issue when I first fire up the car so I thought I would try and get it nailed. Now its actually worse than ever
Old 03-26-2012, 08:59 PM   #5
i would start with what trojan says.hes pretty darn good.
Old 03-26-2012, 09:13 PM   #6
NickMac's Avatar
I changed my egr probably a year and a half ago before I put the stainless magna flow system on... I'll check the vac lines tomorrow
Old 03-26-2012, 09:50 PM   #7
It's probably had enough time to build up some carbon inside.
Just make sure it operates fully and there are no leaks.
Sometimes the replacements you get are not of the best quality too.
P.S. If you have never changed out the O-rings and caps on your injectors, now might be a good time to do that and make sure none were ever left stuck inside the fuel rails and the intake ports.
A vacuum leak around them can cause idle problems too.
rough idle NickAP12589 2011-2014 V6 Mustang 20 04-07-2014 11:11 AM
chrome valve covers for 95 gt???? 95BossGT 1979-1995 Mustang GT 7 03-26-2012 11:50 AM
Engine shaking at idle and driving stangin Pre-2005 V6 Mustang 18 03-22-2012 02:46 PM
Egr valve bolt on manifold. What size wrench? Wshewan 1996-2004 Mustang GT 5 03-20-2012 02:36 PM
Wierd idle shakes and engie light Dylanbest 1996-2004 Mustang GT 39 03-20-2012 12:13 PM
12:34 PM
