poly locks sheered off - Mustang Evolution
Old 03-26-2012, 09:37 PM   #1
Chris01's Avatar
So I have the trickflow street burner kit which I love on my 302 bored .030 over and this is the second time this happened. First time it happen ( cyl 3 exhaust valve) when I was building the motor it broke over night so I thought it was a bad one so I ordered a new one and installed it.. Didnt think noting of it.Now since I have some miles on the motor it started chattering so I thought it was time to adjust them( this happened last week) and today I took the valve cover off and found it sheered off just like before. This time on cyl 7 intake valve. I'm just wonder if anyone has seen and problems like this. I just don't want to be driving and one breaks on me.
First pic is motor in car second pic is when it happen on the engine stand..
ID:	45087   Click image for larger version
Chris01 is offline   Reply With Quote
Old 03-26-2012, 09:45 PM   #2
that sux.it kinda scares me cause i have the same ones on mine.
not to question your skills but did you verify pushrod length and check vulcrum height to make sure everything is right?that kit does come with everything including pushrods,rr, etc right?
Old 03-26-2012, 09:55 PM   #3
Re: poly locks sheered off
You are probably over tightening the set screws.If not then you received a defective set with inferior materials.
Old 03-26-2012, 09:57 PM   #4
Chris01's Avatar
Yea it's the whole top end basically minus throttle body and stuff like that.. But yea I still checked everything the make sure and all was good.. I'm was thinking I just so happen to be the lucky one and get 2 defective parts and hopefully the rest are good
Old 03-26-2012, 09:57 PM   #5
I just hope mine don't do that to! I'm having enough problems as it is.
Old 03-26-2012, 10:05 PM   #6
Amen my friend.
The only pressure on the poly locks at that point is what is put on them with the set screws.
Old 03-26-2012, 10:06 PM   #7
Chris01's Avatar
+1 to that
Old 03-26-2012, 10:10 PM   #8
Amen my friend.
Good to know cause I don't think I got crazy on mine.
Old 03-26-2012, 10:39 PM   #9
Chris01's Avatar
Yea the first one was maybe my fault but I'm going to adjust all of them again since they got a little run time
Old 03-30-2012, 10:41 AM   #10
saleen5.0's Avatar
Tighten them a half turn past snugg then lock the poly locks...while cranking the motor releasing pressure off the valve springs u have to adjust them one at a time.. Wen u see springs released tighten.. Crank motor an tighten other released springs..
saleen5.0 is offline   Reply With Quote
Old 03-30-2012, 10:46 AM   #11
stampde's Avatar
+1
2011 GT Auto
Off road x pipes Srohda 2011-2014 Mustang GT 10 03-25-2012 06:05 PM
Off center pony front grill. Manning3398 2011-2014 Mustang GT 5 03-21-2012 06:25 PM
Off Road H pipe BigB227 1996-2004 Mustang GT 31 03-13-2012 10:31 AM
starter stuck wont turn off!!!! 87_Saleen 1979-1995 Mustang GT 4 03-11-2012 03:19 PM
Line locks? fatblacklab 1996-2004 Mustang GT 10 03-06-2012 08:43 PM
01:23 AM
