Clock spring questions - Mustang Evolution
Old 03-27-2012, 07:13 AM   #1
captain78's Avatar
Ok my airbag light is giving me code 6. According to everything I've read code 6 is a bad clock spring. Problem is everything I've read also says if you have a bad clock spring your cruise and horn won't work either well my cruise and horn both work. I have a chance at getting a steering wheel and airbag off another car in like new condition compared to mine. Would getting this help or not. Any help on the matter would be greatly accepted
captain78 is offline   Reply With Quote
Old 03-27-2012, 07:19 AM   #2
captain78's Avatar
Is that silver thing on back of airbag the clock spring because it doesn't look like the aftermarket ones if not where is the clock spring located
Old 03-27-2012, 09:51 AM   #3
Re: Clock spring questions
I don't think it is. All of them I've seen have a hole in the middle for the steering shaft to go through.
Whatever that is, it might controlled by and connected to the clock spring.
I'd bet it is deeper down in your steering column.
I could not locate one for your car, only the 94-95 Mustangs showed up in searches.
If you locate it I did find a couple of videos that show how they work and how to test and repair them.
Works
Test
Repair
Old 03-27-2012, 10:39 AM   #4
captain78's Avatar
Thanks now I'm just confused about what would be making my air bag light come on flashing that the clock spring is bad even tho my horn and cruise control works.
Old 03-27-2012, 10:48 AM   #5
It could still be the clock spring. There can be several circuits within it and it may be that only the air bag circuit is affected in your case.
Old 03-27-2012, 10:59 AM   #6
captain78's Avatar
Ok just checking thanks
University of Connecticut 9th Annual Spring Show - April 15, 2012 kav05 Regional Mustang Discussion 7 04-14-2012 07:53 PM
Spring! Siendly22 Pre-2005 V6 Mustang 7 03-28-2012 05:43 AM
spring install superboondee 1996-2004 Mustang GT 9 03-27-2012 11:09 PM
Got a couple questions CodyNelson 1996-2004 Mustang GT 2 03-22-2012 08:23 PM
2013 questions STONE47 2011-2014 Mustang GT 99 03-22-2012 05:11 PM
11:39 AM
