Need advise "again" !!! - Mustang Evolution
Old 03-27-2012, 07:12 PM   #1
89 coupe's Avatar
Ok here we go ....... Putting together this 331 and the main support girdle is hitting the oil pump. Do I clearance the girdle or the pump. Also how does a person torque the front main with the pump in the way. Thanks for anyone's input.
89 coupe is offline   Reply With Quote
Old 03-27-2012, 07:49 PM   #2
Re: Need advise "again" !!!
Clearance the girdle.
Picture of issue?
Old 03-27-2012, 07:59 PM   #3
Chris01's Avatar
Sound kinda like u just need to remove the oil pump
Chris01 is offline   Reply With Quote
Old 03-27-2012, 09:38 PM   #4
89 coupe's Avatar
Ok I'm at work (midnight shift) now but first thing this morning I get some and post them.
Old 03-28-2012, 07:21 AM   #5
89 coupe's Avatar
It appears I have to notch the support and either cut a half inch off the stud or order a shorter one. Is this a common problem.
ID:	45204   Click image for larger version
Old 03-28-2012, 09:10 AM   #6
Chris01's Avatar
My guess would be is notch the girdle because if u mess up the oil pump u could destroy your engine.. U need the pump off so u can torque the girdle down first and then replace the pump
I'm sure someone can help you with a little more info
Old 03-28-2012, 09:37 AM   #7
stampde's Avatar
+1
2011 GT Auto
Old 03-28-2012, 03:28 PM   #8
Grind clearance in the girdle.
Cut a bit off of the main stud if you need to.
That way if you ever rebuild and install a new oil pump you won't have to clearance it, which would not be a good idea anyways as it might weaken the pump casting.
Torque the mains down first then install the oil pump.
Make sure you have the oil pump drive shaft and retainer in place before you bolt down the oil pump in case you are not able to install them afterwards.
Old 03-28-2012, 04:38 PM   #9
89 coupe's Avatar
Thanks everyone !!!! That's what I was thinking but wanted to know other thoughts as well. I never used a girdle before and didn't know how much an oil pump casting would take when grinding on it. Thanks again ....!! now on till the next problem which I think it's going to be this Moroso oil pan with half the bolts inside.
Old 03-28-2012, 05:07 PM   #10
Good luck.
If you have issues with the pan, post pictures as I am only familiar with the Canton pans and will need a visual reference.
my car will die and start right back up again! HELP Josh.0 Pre-2005 V6 Mustang 25 06-07-2012 11:47 AM
Need some possitive influence.. FORDGT14 1996-2004 Mustang GT 75 03-30-2012 08:56 AM
17" tires recommendations for 1999 Mustang GT magnum1331 1996-2004 Mustang GT 13 03-28-2012 06:45 PM
Need help/input TX01Stang Pre-2005 V6 Mustang 6 03-26-2012 09:53 PM
Need help locating a part 98 Mustang V6 3.8l kpickett22 Pre-2005 V6 Mustang 11 03-26-2012 08:16 PM
10:20 PM
