86 leaks water from roof, but not from t tops - Mustang Evolution
Old 03-28-2012, 05:30 AM   #1
lilrafe87's Avatar
I have an 86 hatchback w t tops that leaks water from the divider strip on the roof. I did notice a thin long piece of metal was rattling so I removed it and it had rivits in it. I had to remove the headliner to get it out. Any suggestions? Heard that's common on these cars. Thanks
lilrafe87 is offline   Reply With Quote
Old 03-28-2012, 04:09 PM   #2
Re: 86 leaks water from roof, but not from t tops
You probably just need to reseal the T-Tops.
Also check the drain channels and make sure they are not clogged up.
Old 03-28-2012, 05:34 PM   #3
From what I'm gathering he removed it . Put it back with silicon below it . Remoisture the gaskets vasoline works great
tbonestang is offline   Reply With Quote
Old 03-28-2012, 05:41 PM   #4
+1 You can also use spray on silicone lube.
Its DEFINITELY not stock anymore lol...NEW PICS INSIDE!!! CodyNelson 1996-2004 Mustang GT 57 05-20-2012 12:57 PM
what to do when removing a/c from engine black.fox.93 1979-1995 Mustang GT 12 04-10-2012 07:29 PM
Rev from idle problem CoyoteXII 2011-2014 Mustang GT 11 03-27-2012 07:50 PM
those gasoline really evaporate from gas tank? robertoortiz85 1996-2004 Mustang GT 5 03-26-2012 09:27 PM
Making progess removing coating from trunk Seattle66 Classic Mustangs 5 03-26-2012 07:56 PM
12:24 AM
