Electric window gremlins - Mustang Evolution
Old 03-28-2012, 05:25 PM   #1
89Saleen141's Avatar
Passenger window won't roll up. It gave no sign of dying out or anything, it rolled down beautifully and wouldn't come back up. What could be wrong and how can I fix this?
89Saleen141 is offline   Reply With Quote
Old 03-28-2012, 05:29 PM   #2
Re: Electric window gremlins
Switch or motor died.
Test, identify problem component and replace.
Old 03-28-2012, 05:30 PM   #3
aegischief's Avatar
If it quit without weaning like that, it could be the driver side window switch as that is the main.
aegischief is offline   Reply With Quote
Old 03-28-2012, 05:35 PM   #4
The passenger window switch doesn't work as well. I would imagine that the motor would've started making noises if it was about to go out or the window would hesitate to go down.
Old 03-28-2012, 05:40 PM   #5
Not always.
Did you check your fuses?
Old 03-28-2012, 05:41 PM   #6
Not yet, where would I find the fuse box and what would I be looking at, I have limited knowledge on mechanics.
Old 03-28-2012, 05:47 PM   #7
Under the dash at your left knee I think.
Fuse Box - #14
Old 03-28-2012, 06:15 PM   #8
Filibuster
^Yeah its on the left but that diagram is upside down..
The red wire is where I ran the positive wire to bypass my window switches and run my own..
XXSTEVEO66 is offline   Reply With Quote
Old 03-28-2012, 06:20 PM   #9
Yeah, just checked it out. The fuse is the 20c.b. right. All I would need to do is go to my local parts shop and check out if they've got it?
Old 03-28-2012, 06:39 PM   #10
Filibuster
I might call first im not sure how common those fuses are anymore...me personally (redneck ingenuity) would run a jumper in the fuse spot to see if it is the fuse or the switches...though I cant recommend this because it elimanates a fuse and ”could” cause a bad short..
Old 03-28-2012, 06:59 PM   #11
Filibuster
Some of the process of me deleting the switches...
ID:	45277   Click image for larger version
Old 03-28-2012, 07:34 PM   #12
Ok, How's this then?
Name:	89 Mustang Fuse Box.jpg
Old 03-28-2012, 07:36 PM   #13
Filibuster
Haha...muy bueno..lol
Old 03-29-2012, 05:41 PM   #14
Thanks, but would that circuit breaker really go out at only 35xxx miles? I think it may be the power window motor that died.
Old 03-29-2012, 06:24 PM   #15
Filibuster
You never know with electronics they could be bad the day you get them...id still guess its your switches or fuse...the switches are notorious for goin bad on the foxes.I thought the same thing you did but I jumped the motors and they worked just fine saving me $$ and the headache of replacing the motors...always start with your cheapest options first!..
Old 03-29-2012, 06:49 PM   #16
True, I don't know what I'm gonna do. How hard is it to remove the door card?
Old 03-29-2012, 06:53 PM   #17
You mean the door panel?
You should use a door panel removal tool to keep from breaking the panel or fasteners.
Do you know how to use an electrical tester or DMM (Digital Multi-Meter)?
I would begin testing at the switches to see if you have power there and then at the motor to see if you have power there when you press the switch. If you have power at both places then it is likely the motor is bad.
Old 03-29-2012, 07:16 PM   #18
Filibuster
^do this...and IMO the door panels on the foxes are some of the easiest ive delt with!..but like TH said use a removal tool or take your time not to ruin the little ”tree plugs” securing the panel..and dont rip them out from the panel either..
Old 03-29-2012, 07:19 PM   #19
Wow that's a great idea! Yeah i have a digital multi-meter. Thanks for the input, gonna get started on that soon.
Old 03-30-2012, 05:26 PM   #20
Just fixed the problem cause its been raining a lot. It was the switch lol, everyone was right.
---------- Post added at 06:26 PM ---------- Previous post was at 06:23 PM ----------
Fixed it, it was the switch. Thanks for everyone's input, its awesome to have all you guys on here. Really helps out a lot.
Old 03-30-2012, 06:31 PM   #21
Filibuster
Awesome!..
Old 03-30-2012, 06:43 PM   #22
Glad you got it fixed.
Electric fan 04machazblue 1979-1995 Mustang GT 17 03-28-2012 03:57 PM
Window issue? Levinoss Pre-2005 V6 Mustang 2 03-26-2012 06:20 AM
Broken window GenevaGT 1996-2004 Mustang GT 3 03-25-2012 04:00 PM
AM window tint -- did i just ruin it?? RickPollock 2011-2014 Mustang GT 6 03-21-2012 06:41 PM
Window Redman4034 2005-2010 Mustang GT 7 03-21-2012 05:38 PM
05:38 PM
