96 up cruise control help - Mustang Evolution
Old 03-29-2012, 10:14 AM   #1
Titus Wadicus
svtlx's Avatar
does anyone have the wiring diagram/color codes for the wire harness that goes into the cruise control unit itself (in driver side fender).
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Body work help Marcus_2001GT 1996-2004 Mustang GT 9 04-21-2012 09:57 AM
HELP!!!! DaYanks4Ev Pre-2005 V6 Mustang 26 03-30-2012 08:26 PM
Light it up! 11stangGT 2011-2014 Mustang GT 11 03-29-2012 07:12 PM
VAP Intake Spacer- EGR Tube Extension HELP robb15033 Pre-2005 V6 Mustang 1 03-29-2012 06:52 AM
Intake problem! Help! 89 Foxloco 1979-1995 Mustang GT 4 03-28-2012 09:42 PM
04:46 PM
