having problems - Mustang Evolution
Old 03-29-2012, 03:08 PM   #1
mystang50's Avatar
having problems
For some reason my car keeps dieing on me here resently...first happened a week ago droped it from N to drive after sitting at a red light and it acted like it stalled out...started up fine, ran fine...20 miles later did it again, I looked and oil presurs was Jus a hair but lower than normal but everything eles was fine, ain't done it again till yesturday. Stalled out when went from P to R it did it agian. Now its doing it when I go to a stop when its in in D when I get to Jus bout stopping it bucks and dies, died twice went starting it in N going to D...it don't do it if its in N when I go to a stop or if I drop it down to 2 and then to 1 when going to a stop...I checked under hood every thing is good (oil, idels fine, and tranny fluid don't smell burned)...is it possible for tranny to cause it to stall out?? What should be my next steps??
Old 03-29-2012, 03:18 PM   #2
Re: having problems
Have your transmission scanned.
The lock up function of the converter may be failing.
Old 03-29-2012, 03:30 PM   #3
mystang50's Avatar
Allright, ill get it scanned Tomarow
---------- Post added at 03:30 PM ---------- Previous post was at 03:20 PM ----------
Do you know if that is a easy fix??
Old 03-29-2012, 03:40 PM   #4
Re: having problems
No sorry I don't, but you would have to pull the transmission to fix it.
Old 03-29-2012, 03:42 PM   #5
mystang50's Avatar
Yeah figrued
Old 03-29-2012, 03:45 PM   #6
Re: having problems
Yeah figrued
Let's just hope that it is ok and the problem lies elsewhere.
Old 03-29-2012, 05:09 PM   #7
mystang50's Avatar
Idk what eles it could be...tranny was rebuilt mabye 2 yrs ago
Old 03-29-2012, 05:24 PM   #8
95v686gt's Avatar
Lock up staying engaged could make it buck and die. First thing is first got to check the ecu to see if any dtc's are there. If you can find a shop that has a snap on or equivalent scanner will save you some bucks. Not sure but it should have a lock up relay somewhere that may be sticking.
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 03-29-2012, 06:46 PM   #9
mystang50's Avatar
Dtc?? Where could the lock up relay be??
Old 03-29-2012, 07:25 PM   #10
95v686gt's Avatar
Dtc= diagnostic trouble code
Either in the relay center under the hood or mounted on the firewall. Just get the trouble codes first and start there. Do not go by a auto parts store to get the codes cause they will try to sell you every part that comes up bad.
Old 03-29-2012, 07:30 PM   #11
mystang50's Avatar
Wow can't believe I didn't catch that Dtc hahaha...and ill try Tomarow...would yall suggest a tranny shop or Jus any good auto shop??
Old 03-29-2012, 07:31 PM   #12
95v686gt's Avatar
Any good auto shop with a scan tool can do it.
Old 03-29-2012, 07:36 PM   #13
mystang50's Avatar
yeah...figured, Jus getting yalls opinion, there is also like a rattling kinda like a suckshion too noise when its in P and goes away if I put in on N and vice versa...is there some kind of lines that go to tranny that could've came loose??
Old 03-29-2012, 08:03 PM   #14
95v686gt's Avatar
Rattle like a bearing out rattle? Only lines would be the fluid lines and you'd notice if it's leaking.
Old 03-29-2012, 08:36 PM   #15
mystang50's Avatar
Not like a bearing going out...its hatd to explain...kinda like a fan noise
Old 03-29-2012, 08:40 PM   #16
95v686gt's Avatar
Interesting. Sounds just like a converter issue.
Old 03-29-2012, 08:41 PM   #17
Re: having problems
Probably a torque converter or pump issue.
Old 03-29-2012, 08:42 PM   #18
95v686gt's Avatar
Agreed.
Old 03-29-2012, 08:56 PM   #19
Re: having problems
Originally Posted by 95v686gt View Post
Agreed.
We must have been typing those answers up at the same time.
Old 03-29-2012, 09:01 PM   #20
95v686gt's Avatar
Great minds think alike. Been working on cars and trucks since I was 15.
Old 03-29-2012, 09:27 PM   #21
Re: having problems
Hahaha, yes indeed.
I bought my first car when I was 13 years old.
Been tinkering and building them ever since.
Old 03-29-2012, 09:31 PM   #22
95v686gt's Avatar
Yeah. Nice mustang pic you got there. Reminds me of my 86 GT
Old 03-29-2012, 09:40 PM   #23
Re: having problems
Thanks, That's the actual "Trojan Horse".
Minus the fake blower engine of course.
Like the original, "It's what's inside that counts".
Old 03-29-2012, 09:46 PM   #24
95v686gt's Avatar
Mine is called SS killer. Even has it on the back glass.
Old 03-29-2012, 09:55 PM   #25
Re: having problems
It's not nice to tease the "Super Slows".
Old 03-29-2012, 10:02 PM   #26
95v686gt's Avatar
Or "Stupid Sloths"
Old 03-30-2012, 11:43 AM   #27
mystang50's Avatar
went to shop and got it scanned...only 1 code and it was tranny temp sensor...they told me to clean out maf and t/b...they gave me a can of B-12...they told me spray it in tha maf when it was running, the other time I cleaned it I Jus took it off...does it matter witch way I do it??
Old 03-30-2012, 12:18 PM   #28
95v686gt's Avatar
Get the speciality cleaner for the maf. I'd clean it off the car with the maf cleaner. What was the code number for the temp sensor? Should of been p something.
---------- Post added at 11:18 AM ---------- Previous post was at 11:02 AM ----------
I run a can of b-12 chemtool thru a tank of gas to keep my fuel system somewhat clean. Didn't know they made maf cleaner though.
Old 03-30-2012, 12:56 PM   #29
mystang50's Avatar
All I heard was 606 he pulled out his iPhone and looked it up...he tried to get the temp of tranny but didn't pull it up...that's what they told me that b12 would work...they gave it to me for free
Old 03-30-2012, 01:37 PM   #30
Sorry all what's b12 . Haven't seen or heard that one
tbonestang is offline   Reply With Quote
Old 03-30-2012, 02:26 PM   #31
93slowstang's Avatar
A brand, they make carb/tb cleaner, starting fluid and a few other things.
Old 03-30-2012, 03:13 PM   #32
Re: having problems
Nope, B12 is a vitamin. Gives your MAF that little extra "boost" of power it's been missing lately.
P.S. Just so this doesn't get misunderstood by some, "That's a joke."
Old 03-30-2012, 04:26 PM   #33
Took me a sec, that's great.
Old 03-30-2012, 04:26 PM   #34
95v686gt's Avatar
It's steroids for your stang. B-12 is made by berrymans and I swear by the stuff for the fuel system. I'll look up the code and get back to you.
Old 03-30-2012, 07:24 PM   #35
mystang50's Avatar
Tranny shop said its converter...
Make Ford recall these problems!!! ...800-392-3673 Lalayla 2005-2010 Mustang GT 62 12-11-2013 08:59 AM
Any problems with Bama tunes Sprintradc 2011-2014 Mustang GT 37 03-31-2012 12:12 PM
Pulleys problems yankeegt07 2005-2010 Mustang GT 8 03-26-2012 04:30 PM
Radiator Fan problems SCenteno112 Pre-2005 V6 Mustang 2 03-23-2012 07:54 AM
My arch nemesis... Drive-ability problems :( Otlaw80 1979-1995 Mustang GT 17 03-22-2012 07:47 PM
10:08 PM
