5.0 tune up help - Mustang Evolution
Old 03-29-2012, 11:57 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
5.0 tune up help
i have a 93 5.0 rolling up to 140k runs good cai long tube headers straight dumps and am looking to do a good tune up on everything I can do myself I am pretty good with cars but not mechanic I just enjoy working on them. so any tune up ideas I can handle myself and/or products to use like brand of wires plugs and size of wires ect. it has ford racing wires but I'm not sure how old
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 03-30-2012, 12:30 AM   #2
Re: 5.0 tune up help
1. Buy a Chilton's or Haynes manual for your car. Make sure it has the wiring diagrams as they can be very useful.
2. Follow the tune up directions and specifications in the manual.
3. When replacing the distributor cap/rotor always buy the ones with brass contacts. The aluminum contact caps/rotors do not last long and are usually cheaply made.
4. Ford Racing 8mm plug wires will work fine unless you have a high powered aftermarket ignition system.
5. Stick with the Autolite spark plugs. Most of the "gimmick" spark plugs are not worth carrying home.
6. Set your timing as shown in the manual. 10 degrees BTDC is the stock setting. You can advance it to 12 -16 degrees BTDC, but that may require you to run a higher octane fuel at the more advanced settings.
Advance the timing in 2 degree increments and test drive the car after each 2 degree increment advancement. If you hear it pinging, then back the timing off 2 degrees and leave it there. What you are hearing when it pings will be the engine detonating, which can destroy your engine if it is ran in that condition for very long.
Old 04-03-2012, 06:16 PM   #3
slow281
sixpac's Avatar
Region: Nebraska
Chilton or Haynes which do you reccomend
2001 GT - True Blue
Old 04-03-2012, 06:19 PM   #4
Filibuster
I perfer chilton,but I have haynes for my fox and it has all the info you'll need!..
XXSTEVEO66 is offline   Reply With Quote
Old 04-03-2012, 06:56 PM   #5
I prefer Chiltons too.They have more and better information IMO.
Old 04-03-2012, 07:11 PM   #6
I agree. But the only problem is a lot of time the local stores only carry Haynes.
Old 04-03-2012, 07:33 PM   #7
Filibuster
Thats exactly why I have haynes for both my stang and camaro..:/
Old 04-04-2012, 03:16 AM   #8
Order online from Amazon.Occasionally you can find slightly used or new for less than you can get them local.
Body work help Marcus_2001GT 1996-2004 Mustang GT 9 04-21-2012 10:57 AM
Competition is heating up! btlefed At the Track 29 04-07-2012 09:08 PM
Light it up! 11stangGT 2011-2014 Mustang GT 11 03-29-2012 08:12 PM
96 up cruise control help svtlx 1979-1995 Mustang GT 0 03-29-2012 11:14 AM
Just purchased a new 5.0 mustang RuSSiaNStuDD 2011-2014 Mustang GT 0 03-28-2012 11:37 PM
04:10 PM
