Broken bolt ? - Mustang Evolution
Old 03-30-2012, 07:50 PM   #1
Taxman's Avatar
What happens if I put the water pump on with out this bolt
I tried an easy out with no luck...
Taxman is offline   Reply With Quote
Old 03-30-2012, 08:56 PM   #2
Re: Broken bolt ?
It will probably leak. Isn't that near one of the block passages?
Is there enough bolt left to weld a nut onto?
Old 03-30-2012, 08:59 PM   #3
If not he may have to pull the timing cover.soak the bolt In a good penetrating oil, and pray.I prefer aerokroil.
Old 03-30-2012, 09:04 PM   #4
Re: Broken bolt ?
Good idea.
A reverse direction drill bit is handy for drilling out broken bolts too.
Since you run the drill in reverse, if the bit catches it will sometimes spin the bolt out for you.
Old 03-30-2012, 09:05 PM   #5
Filibuster
Aerokroil!..where the F can I find that?!..
XXSTEVEO66 is offline   Reply With Quote
Old 03-30-2012, 09:24 PM   #6
You have to get it online.I have a guy that I work on his car.he pays me in aerokroil and mechanics glove cause he works at a mill.lol.but this stuff is amazing!!!!!!
Old 03-31-2012, 11:12 AM   #7
Kenny laird's Avatar
Same thing happen to me but five of them broke when changing water pump. I pulled timing cover soaked them with penitrating fluid and was able to get them out it was a 3 day nightmare but it worked
Kenny laird is offline   Reply With Quote
What do you think about this bolt on is it worth it Mustangpower5.0 2011-2014 Mustang GT 12 05-17-2012 09:42 AM
Broken window GenevaGT 1996-2004 Mustang GT 3 03-25-2012 05:00 PM
starter bolt 93_347foxbody 1979-1995 Mustang GT 3 03-20-2012 09:39 PM
Egr valve bolt on manifold. What size wrench? Wshewan 1996-2004 Mustang GT 5 03-20-2012 03:36 PM
broken l2plagears Pre-2005 V6 Mustang 1 03-07-2012 09:47 PM
06:14 PM
