rear seat delete - Mustang Evolution
Old 03-30-2012, 07:29 PM   #1
351mustanggt's Avatar
rear seat delete
Has anyone built a rear seat delete? im thinking of doing it. and on that note does anyone know how to remove the vertical part of the back seat?
351mustanggt is offline   Reply With Quote
Old 03-30-2012, 07:44 PM   #2
93_347foxbody's Avatar
Re: rear seat delete
there should be screws that you un-screw and it should come off i think i havent taken it off yet just noticed em from the trunk, and they sell rear seat deletes on fox resto if youre looking to buy one: Fox Mustang Restoration :: Products
---------- Post added at 09:44 PM ---------- Previous post was at 09:42 PM ----------
idk if its the same for coupes and hatchbacks
93_347foxbody is offline   Reply With Quote
Old 03-30-2012, 07:46 PM   #3
I don't remember cause its been a while.but I'm pretty sure there is no screws.what you do is push in on the seat and either up or down.there are tabs on the back of the seat.if you pull the top part of the seat away just a little you should be able to see how they come off.
Old 03-30-2012, 07:50 PM   #4
i couldve swore there was screws holding the hinge type thing for the upper part on the hatchbacks
Old 03-30-2012, 07:52 PM   #5
It's possible.mine is a vert so maybe they are different
Old 03-30-2012, 08:13 PM   #6
mines a vert so ill look and see if it slides. i know the places lmr and am have em but it appears that its just a few brackets and some fiberboard/plywood and some carpet and i think i could do just about the same for like 25 bucks
Old 03-30-2012, 08:28 PM   #7
If you are talking about the rear seat, back section, there are two bolts at the bottom.
Remove those, then lift up and away to disengage the hooks at the top.
I plan on a rear seat delete too, but I will be fabricating mine out of aluminum so it will act as a firewall too. I'm moving the battery to the back and I may install an aftermarket fuel tank too, so some extra protection may be in order there.
Find some large pieces of cardboard and using some duct tape along with it you can easily make a pattern before you start cutting your seat delete material.
Old 03-30-2012, 08:43 PM   #8
thx for the tip. i will post pics when i get to doing it.
Spoiler delete BDSA1NT 2005-2010 Mustang GT 19 04-01-2012 09:16 PM
7.5 rear end Surffer227 Pre-2005 V6 Mustang 43 03-31-2012 09:56 PM
rear seat delete Sprintradc 2011-2014 Mustang GT 20 03-31-2012 05:25 PM
Cat delete CoyoteXII 2011-2014 Mustang GT 15 03-30-2012 08:45 AM
Rear bumper Auntmanda012 Mustang Paint, Appearance & Detailing 5 03-29-2012 07:01 PM
05:39 PM
