NEED ADVICE - Mustang Evolution
Old 04-01-2012, 10:34 PM   #1
Pmlaker's Avatar
How to get 300 HP?
Hi,
I'm a newbie.....posting for the first time on this site. Have 1990 black convertible 5.0...and $10K. Trying to get some ideas from fellow mustang owners on how to get to 300hp!
Pmlaker is offline   Reply With Quote
Old 04-02-2012, 12:07 AM   #2
88fox's Avatar
If you get a H,C,I combo from LMR it can put you up too 350 HP but its a little pricey
88fox is offline   Reply With Quote
Old 04-02-2012, 12:11 AM   #3
Re: How to get 300 HP?
Originally Posted by Pmlaker View Post
Hi,
The quickest and probably easiest way barring using nitrous would be to install a Trick Flow top end kit.
The kit in the link should net you around 360 HP.
Old 04-02-2012, 01:00 AM   #4
Prados86gt's Avatar
Do it right. U have the appropriate funds, build everything from the bottom up. Heads, pistons, pistons rings, injectors, manifold upper and lower, exhaust, pulleys, everything.
---------- Post added at 01:00 AM ---------- Previous post was at 12:57 AM ----------
Cams, gears, rear end, eliminated everything that is not needed if ur gna build ur stang for power.
Prados86gt is offline   Reply With Quote
Old 04-02-2012, 01:57 AM   #5
Or with 10K to spend just go here - Ford Strokers
Old 04-02-2012, 05:14 AM   #6
Taxman's Avatar
Hi,
How many miles are on your motor?
If you ask me it's pointless to build the top end an have the "old" bottom end..
Think of it like a foundation for a building... You don't want the taj mahal built on a swamp!!
If your gonna invest time an money, do it right!
An 10k is more than enough to build 300hp
Taxman is offline   Reply With Quote
Old 04-02-2012, 07:08 AM   #7
Sell ur current stang add the 10k u have too it and by a 2005 I believe they cam stock 300hp. Now that the easiest .
tbonestang is offline   Reply With Quote
Old 04-02-2012, 08:39 AM   #8
Pmlaker's Avatar
NEED ADVICE
Have 1990 gt 5.0 convertible.....have 10K in budget. Need advice on where to begin for 300 hp! Already purchased front end & rear kit from late model resto.
Old 04-02-2012, 08:44 AM   #9
Titus Wadicus
svtlx's Avatar
Re: NEED ADVICE
its blower time!!! best bang for your buck....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-02-2012, 09:18 AM   #10
ColeJohnson's Avatar
Re: NEED ADVICE
I would go with new tires/rims, short shifter, rear upper/lower control arms, and a blower. And with whatever is left start saving up for a cam, intake, and heads!
2016 Comp Orange GT (current)
Old 04-02-2012, 09:22 AM   #11
Re: NEED ADVICE
300hp (flywheel) should be VERY easy to get with a nice motor build. The right intakes/ heads/ cam will have you there. Just be sure to spend money where its needed. If 300 is your goal and your goal for a long time you wont need any forged internals really etc.
Old 04-02-2012, 11:09 AM   #12
10 k will make you a pretty bad a$$ stang.you could get your 300 and still do suspension,tires,gears etc etc.
Old 04-02-2012, 12:41 PM   #13
What would the coyote cost him
Old 04-02-2012, 01:00 PM   #14
Just the motor,probably 6-7k.plus whatever it takes to get it in there.that would be sick though.
Old 04-02-2012, 02:18 PM   #15
93_347foxbody's Avatar
Re: NEED ADVICE
put a 351 in it and go from there lol
93_347foxbody is offline   Reply With Quote
Old 04-02-2012, 03:27 PM   #16
I believe in 5.0 they did the whole thing for like 9500 soup to nuts and that would be a sick combo. I would gets the 3.8 tags
Old 04-02-2012, 07:31 PM   #17
yes that would be totally sick.as light as a fox body is that thing would scoot.and also have oem reliability with decent mpgs.
I need MAF conversion for dummies 87blackonblack 1979-1995 Mustang GT 82 04-16-2012 09:40 PM
need help with fluid decision 5.ohhhhh 2011-2014 Mustang GT 23 04-04-2012 09:00 PM
I need some help dhktactical Pre-2005 V6 Mustang 6 04-02-2012 08:10 AM
Deep scratch need help Mustang240 General Mustang Discussion 9 04-01-2012 12:01 PM
Need help with Hid kit Noerrors8 General Mustang Discussion 22 04-01-2012 11:24 AM
04:52 PM
