Holley Systemax Intake - Mustang Evolution
Old 04-02-2012, 10:36 AM   #1
89Saleen141's Avatar
What is the difference between the holley systemax 1 and 2. How can I tell the difference between the two?
89Saleen141 is offline   Reply With Quote
Old 04-02-2012, 01:56 PM   #2
Re: Holley Systemax Intake
Not 100% sure, but I have read that;
The Systemax I is just an upper that works with a stock truck lower and the Systemax II is the complete upper and lower.
I also found this statement;
The Systemax I is the same as the truck intake (F150's w/ 302). The Systemax 2 is newer and has a higher RPM range.
Then I found this in a magazine article, which I believe to be the correct answer;
The Systemax I intake is similar in design to the Vortech/Saleen intake that used a 5.0 truck lower intake. The SysteMAX II uses an improved, Holley-specific lower design .
You would want the Systemax II intake, if that is the brand you are going for.
You can tell the difference by the lower intake. The Systemax I uses a Ford truck lower and the Systemax II uses a Holley specific lower.
Old 04-02-2012, 02:08 PM   #3
Thanks a lot. I'm buying a used one from a guy locally without the bolts and gaskets for 400 and I was wondering how to tell which is which.
VAP Windstar intake kit Kingmidas87 Pre-2005 V6 Mustang 12 04-12-2012 02:11 AM
Intake chockes rough idle Blackedout Pre-2005 V6 Mustang 5 04-02-2012 03:11 AM
intake question! lemons95 Pre-2005 V6 Mustang 4 04-01-2012 11:09 PM
Intake manifold bolts 89Saleen141 1979-1995 Mustang GT 5 04-01-2012 06:58 PM
intake carb and valve covers dreamstang Classic Mustangs 0 03-31-2012 10:41 PM
08:54 PM
