Voltmeter - Mustang Evolution
Old 04-02-2012, 03:56 PM   #1
Ohdang1990's Avatar
Voltmeter
So im not new to the mustang world. In fact this is my second 88 gt. but i need some help. when i start the car it starts strong and the volts are right where they should be, but once it warms up it starts acting wierd. the volts will sometimes drop very low and even dangerously low when the lights are on. Ive never owned an automatic but it does it the worst when i put it in reverse. Ive changed the battery, alternator, and pigtail for the alternator. my guess is there is a short somewhere. Im just wondering if anybody else has ever had this problem and could maybe give me a few tips on where to look first. it idles fine but also bucks a little when at cruising speed but accelerates and slows down fine.
Ohdang1990 is offline   Reply With Quote
Old 04-02-2012, 04:19 PM   #2
Re: Voltmeter
Do you have under drive pulleys?
Have you checked all of your ground connections?
Is the idle set to the correct specification?
Is your under wear too tight?
Have you checked and cleaned the IAC?
Have you checked and cleaned the MAF?
Have you checked the intake and vacuum connections for leaks?
Have you ever replaced the TPS?
Old 04-02-2012, 04:47 PM   #3
Ohdang1990's Avatar
Re: Voltmeter
i dont have under drive pulleys and i dont have MAF and ive checkedfor vac leaks and my underwear seems to be fine. Ill try the rest of that stuff. thanks a lot
Old 04-02-2012, 04:55 PM   #4
Re: Voltmeter
You're welcome the underwear line was just a joke.
Old 04-02-2012, 05:14 PM   #5
Ohdang1990's Avatar
Re: Voltmeter
so turns out that i do have under drive pulleys. but onlyfor the harmonic balancer and waterpump and there wasnt an under drive pulley on the alt that i replaced
Old 04-02-2012, 05:18 PM   #6
95v686gt's Avatar
Check for a bad battery cable. See if you can bend it, if it feels brittle replace it.
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 04-02-2012, 05:33 PM   #7
Re: Voltmeter
I'd replace all of them with stock pulleys, but that's your choice.
It would possibly alleviate any future cooling or charging issues.
The balancer pulley may still be slowing down your alternator as it is the "drive" pulley for all of the other "driven" components.
Old 04-02-2012, 06:14 PM   #8
+1. As I started reading through this my first thought was ud pulleys.then you posted it.then as he stated more I was thinking still the crank pulley, and then you stated that.lol.you beat me to the punch. Lol I would go back to stock also.
Old 04-03-2012, 05:38 AM   #9
Ohdang1990's Avatar
Thanks a lot everybody. I'm feeling pretty confident that it is the pulleys. Anybody know a good place to get the stock set for cheap?
Old 04-03-2012, 05:55 AM   #10
95v686gt's Avatar
Try a pull a part or a local shop might have some just laying around.
04:13 PM
