Lakewood adjustable traction bars - Mustang Evolution
Old 04-03-2012, 02:25 AM   #1
Punks86coupe's Avatar
Hey there people on quick question I just purchased some used traction bars for my 86 coupe lx I installed the traction bars but they didn't come with the reinforcement plate. The guy told me I can still use the traction bars like that. It dies have that bushing where it would be by the chassis I think it's called snub or something like that. Well my question is does that snub suppose to be touching the bottom of my chassis like right on it or do I have to leave a gap between the snub and the chassis of my car. It is about a inch in gap right now and it's getting annoying when I accelerate my car and I get a thumping sound plz help
---------- Post added at 11:25 PM ---------- Previous post was at 11:23 PM ----------
I also installed new upper and lower control arms with poly bushings aftermarket forgot brand name
Punks86coupe is offline   Reply With Quote
Old 04-03-2012, 12:55 PM   #2
Re: Lakewood adjustable traction bars
Sounds like those are for older leaf spring cars.
I would not try to use them on your car or you will eventually damage something.
Do you have a picture?
Old 04-03-2012, 03:03 PM   #3
the only lift bars I have seen with a spring setup replaces the stock lower control arms and just has a bracket to lower their mounting position so you get more of an angle (further down on the axle mount location)
Old 04-03-2012, 03:26 PM   #4
I'm pretty sure he is talking about an old set of "slapper" bars that are used on leaf spring rearends.If he has those on there smacking up against the bottom of the car sooner or later he will rip a hole in the under body.
Old 04-03-2012, 04:26 PM   #5
Nan never saw them on a stang but in 80 gm yes with springs
tbonestang is offline   Reply With Quote
Old 04-05-2012, 02:28 AM   #6
This is a link of what they look like. They are seperate from the lower control arm. I do not have the front piece where it would bolt up to the chassis (the chrome square piece) but their is a bump there.
http://s7d4.scene7.com/is/image/Turn5/37205?$s7product$
---------- Post added at 11:28 PM ---------- Previous post was at 11:26 PM ----------
No not for leaf springs running a 91 gt 8.8 dif. On my 86 coupe with quad shocks
Old 04-05-2012, 02:46 AM   #7
Those are very similar to the slapper bars, but they need to be bolted up to the front mounts with U-bolts and pre-gapped so they work properly. Note that they will limit your suspension travel.
Here is a link to the instructions - Lakewood Traction Bars
I would get rid of those and just install a set of the UMI Lift Bars instead.
They will take the place of your stock control arms and not add as much weight or complexity to your rear suspension. They also work really well at planting the rear tires and they won't limit your suspension movement.
rebuilding traction-lok lsd 91BlueMule 1979-1995 Mustang GT 10 03-12-2012 06:05 PM
fox body sway bars 2300turboford 1979-1995 Mustang GT 3 03-02-2012 09:02 PM
Traction Control JTeel1781 2005-2010 Mustang GT 4 02-22-2012 11:21 AM
Traction problem 04machazblue 1979-1995 Mustang GT 11 01-31-2012 09:53 PM
Traction control Daveeemoon 2011-2014 Mustang GT 21 01-31-2012 08:31 AM
10:27 PM
