Need vaccum line help - Mustang Evolution
Old 04-03-2012, 12:40 PM   #1
CatchMe's Avatar
Ok i put a motor in my car and i have a factory 5.0 intake on it ho of course and took all the smog stuff off beins my motor came out of a different car and i have one vaccum line on the intake w no home and it is critical to be hooked up its the one that goes to.the canister purge valve i have all the purge valve but have no clue where its supposed to hook to and car has a lil miss to it and no power what so ever it idles.great and when i try to.drive it runs like.crap any help would be grewtly apprecuated
CatchMe is offline   Reply With Quote
Old 04-03-2012, 12:57 PM   #2
Re: Need vaccum line help
What year is your car?
Old 04-03-2012, 01:30 PM   #3
CatchMe's Avatar
89 sorry trojan i forgot to put that
Old 04-03-2012, 02:13 PM   #4
Here is a typical vacuum diagram.
Old 04-03-2012, 03:40 PM   #5
CatchMe's Avatar
Ok trojan that makes sense now heres the real quiestion will it run right w out the canister hooked up? In simple terms will a stock intake work w all the smog pump system removed and run correctly?
It may be out of time real bad im probably going to have to pull distributor out for the 15 th time its not been right since i got tue motor in i dont think ... it idles amazing but has a little shake to it and it drives like its a festiva from the 80 s
---------- Post added at 03:40 PM ---------- Previous post was at 03:38 PM ----------
Also trojan i have a vaccum line under neath the intake as right behind the distributor and its a nipple right beside where the pcc hose bends and goes back to the back of the intake idk where that one goes thats the one in quiestion that diagram doesnt show that one
Old 04-03-2012, 03:59 PM   #6
It will run ok. You may need to fabricate or purchase an EGR Eliminator (search that on this forum for a diagram) to keep the CEL light off.
When re-stabbing the distributor make sure #1 cylinder in on TDC, on the compression stroke. Then you install the distributor with the rotor pointing at #1 plug wire terminal.
In the diagram above it is showing the intake "manifold vacuum" lines.
There are 4 and it is shown on the right side of the drawing.
Old 04-03-2012, 10:41 PM   #7
CatchMe's Avatar
Got it figured out rewlized the motor i am using is a non ho motor amd my plug wires were wrong gesus this thing hauls major butt lol its running awesome now and thatnks for all the help
Need HELP! Gobabygo67 Mustang Paint, Appearance & Detailing 18 04-08-2012 01:04 AM
Aftermarket head unti help BigB227 Mustang Audio & Video 6 04-05-2012 11:06 PM
need help with fluid decision 5.ohhhhh 2011-2014 Mustang GT 23 04-04-2012 10:00 PM
Mid-pipe/catalytic converter/emissions help NeedSomeMods 1979-1995 Mustang GT 18 04-03-2012 02:33 PM
NEED ADVICE Pmlaker 1979-1995 Mustang GT 16 04-02-2012 08:31 PM
10:32 AM
