Dropping oil pan - Mustang Evolution
Old 04-03-2012, 04:21 PM   #1
Taxman's Avatar
Is it possible to do it with out lifting the engine?
I jut need to run a magnet to get out a washer.... 
....95 gt vert.
Taxman is offline   Reply With Quote
Old 04-03-2012, 04:30 PM   #2
Bane-'s Avatar
Re: Dropping oil pan
you can drop it some without lifting, but I dont know if you will still have enough clearance. Wont be much room to work with at all.
Old 04-03-2012, 04:32 PM   #3
I don't think you have to pull the engine but at least lift it some.
Old 04-03-2012, 05:02 PM   #4
Taxman's Avatar
Doesn't the oil pickup have a screen on it?
Old 04-03-2012, 06:52 PM   #5
Filibuster
Not sure if it has the same k-member setup n all as the foxes,but on mine you had to lift the eng a little and unbolt the oil pickup two bolts and kind of a tight squeeze but definitely possible...
---------- Post added at 07:52 PM ---------- Previous post was at 07:51 PM ----------
Yeah there is a screen at the bottom..
XXSTEVEO66 is offline   Reply With Quote
Old 04-04-2012, 02:31 AM   #6
Pull the water pump and front cover maybe?I have fished dropped oil pump driveshafts out that way.
Old 04-04-2012, 05:10 AM   #7
Taxman's Avatar
That's what I was doin, changing the gasket behind the timing cover.... Then I dropped a washer in pan.... I may run it like that.....
I worry about it getting in the rotating assembly more then the oil system.
Old 04-04-2012, 01:33 PM   #8
It's possible. A friend of mine left an oil pump shaft in his oil pan figuring it would not move, but somehow it did and took out his engine.
That's why I fished mine out using a small, powerful magnet on a spring like stalk.
Old 04-04-2012, 01:52 PM   #9
Speaking of.could he pull his distributor and go through that hole with a long magnet like you speak of?
Old 04-04-2012, 02:21 PM   #10
Possibly, but you'd have the distributor support casting and the oil pump to contend with.
Best oil for your mustang? JR_GT500 Shelby Mustang 28 07-19-2012 08:34 PM
Temp and oil sensors on a 68 Tyoung68 Classic Mustangs 4 04-02-2012 08:45 PM
Replacing Oil Pan gasket.... DaYanks4Ev Pre-2005 V6 Mustang 23 04-01-2012 07:00 AM
Oil pick up clearence 89 coupe 1979-1995 Mustang GT 1 03-31-2012 08:07 PM
Crazy oil pressure 96svt mystic Moose8878 SVT Mustang 0 03-30-2012 08:40 PM
04:59 AM
