95 GT - Mustang Evolution
Old 04-04-2012, 01:17 PM   #1
NickMac's Avatar
95 GT
The stang pulled the same stuff it did last time by not starting when it was cooler outside (50) . It would turn over but acted like it was not getting fuel... Took the negative cable off charged her for awhile and it fired right up... I adjusted the idle to about 800 and its running good. Still feels like the idle is sticking alittle in the lower gear and my check engine comes back on when the car gets warm.
NickMac is offline   Reply With Quote
Old 04-04-2012, 02:25 PM   #2
Re: 95 GT
You battery probably has a cell going dead in it.
The CEL may be from problems with your EGR valve, you will probably have to have it scanned to be sure.
Old 04-05-2012, 05:59 PM   #3
NickMac's Avatar
I'll pull the EGR off and check it... Thanks alot
Old 04-05-2012, 06:10 PM   #4
Re: 95 GT
Clean it while it is off and check the diaphragm for leaks.
Old 04-08-2012, 02:50 PM   #5
NickMac's Avatar
Is there any certain way to clean tge EGR
Old 04-08-2012, 03:42 PM   #6
Re: 95 GT
Remove it and clean out the carbonized oil deposits with a good carb cleaner.
Then apply vacuum to the vacuum line and ensure that the valve operates.
You can use a clean piece of hose and your mouth or a vacuum tester to apply the vacuum.
Old 04-10-2012, 11:12 PM   #7
justjake94boss's Avatar
Ya I'm getting and egr clogged code
justjake94boss is offline   Reply With Quote
Old 04-11-2012, 01:24 PM   #8
Re: 95 GT
Then clean that sucker out.
Also be aware there is a vacuum switch associated with the EGR that can fail and it will give a code for the EGR too. So if you clean the EGR and it is working properly, but you still get a code, that could be the culprit.
Just bought a new 2012 mustang GT RuSSiaNStuDD 2011-2014 Mustang GT 77 04-20-2012 10:08 AM
Conversion: 2011 GT/CS to Boss 302 Snyderized 2011-2014 Mustang GT 29 04-10-2012 06:48 PM
stock pulleys 95 5.0 NickMac 1979-1995 Mustang GT 29 04-07-2012 08:03 AM
03 gt vs 05 gt Doe_Rae_mi 1996-2004 Mustang GT 37 04-07-2012 01:13 AM
Gt hood scoop made functional? Blackedout Pre-2005 V6 Mustang 8 04-03-2012 09:29 PM
06:02 PM
