Idleing when it starts - Mustang Evolution
Old 04-04-2012, 06:09 PM   #1
laVey420's Avatar
So when u start my 5.0 it idles for about 30 to 45 seconds den it's normal also have a small oil and power steering leak there's smudge in da engine on certain spots I'm not a mechanic but I love mustangs foxbodys most so I wanted info on how to fix and who to go to , also how much for all this.
laVey420 is offline   Reply With Quote
Old 04-04-2012, 06:23 PM   #2
whats wrong with the idle when you start it.it may idle a little high untill its warmed up.that would be normal.
where are leaks coming from?on the power steering pump if its the case it maybe repairable with some epoxy.but also the price of a remanufactured unit is pretty cheap on places like summit racing.i think i paid 50-60$. if its the hose just try tightening it or picking up a new one from your local auto parts store.
the oil leak we need to know where its coming from.if its hard to tell, clean all the wet/oily areas really good with some degreaser and keep a close eye on it.the cleaning will help see where its coming from.
Old 04-04-2012, 06:31 PM   #3
laVey420's Avatar
Well the oil I'll look for but I've lost power in first I burn rubber while shifting to second it won't , and the smudge is dat from the oil or wut anyways I'll also check on the power steering hose
---------- Post added at 07:31 PM ---------- Previous post was at 07:28 PM ----------
Oh and no it idles low not high den after 30 sec it goes high and sound normal mines sounds like it has a cam everybody hears it and wants I lie and say hellyea I got one but no it sumtimes feels like its gna die but doesn't
Old 04-04-2012, 11:33 PM   #4
Re: Idleing when it starts
Check your EGR valve make sure it is working and it probably needs to be cleaned even if it is working.
Check for any vacuum leaks in the EGR and what it is connected to.
Old 04-05-2012, 10:32 AM   #5
laVey420's Avatar
So is dat da reason why it's losing power or wut cuz car seems fine except when I'm hauling *** or about to race
Old 04-05-2012, 03:24 PM   #6
I would suspect a fuel delivery or timing issue.
You should check your fuel pressure, at idle, with the vacuum line disconnected and plugged.
It should be in the 38-40 psi range.
Also check your timing, stock is 10 degrees BTDC.
Advancing it will get you some power, but don't go so far that it detonates as that could destroy your engine. 12-16 degrees is the normal advance range. Advance 2 degrees at a time and test drive, if you hear pinging or rattling back it off a degree or two and lock it in there.
Don't forget to replace the spout connector when you have finished each time.
Old 04-05-2012, 06:42 PM   #7
laVey420's Avatar
Already appreciate it will do thanks for da advice I'll get back to u as soon as Its better or worse hopefully not.
Old 04-05-2012, 07:01 PM   #8
Ilovemustangs88's Avatar
Mine wouldn't idle right either when I first started up. But sometimes mine took a couple times to start. Not sure if yours is doing that. But mine was the fuel rail pressure sensor. I would have it hooked to a code reader and see what comes up
Ilovemustangs88 is offline   Reply With Quote
Old 04-06-2012, 11:05 AM   #9
laVey420's Avatar
Alright will do
What it takes for forced induction and much more... dreamstang 1979-1995 Mustang GT 2687 10-31-2012 11:50 AM
a body kit for foxbody mustangs that makes it look like a 60s mustang ? Haav 1979-1995 Mustang GT 24 04-19-2012 10:38 PM
loud squeal noise when certain rpms? Cobra209 SVT Mustang 13 04-06-2012 05:42 AM
How long will it last? GrabberBlue5.0 General Mustang Discussion 9 04-05-2012 07:21 AM
08:01 PM
