need picture - Mustang Evolution
Old 04-04-2012, 11:07 PM   #1
tc x 4's Avatar
need picture
My 83 throws the belt. There is no idler or tension pully on it. The powersteering pump has the sq hole for ratchet, but the bracket that holds it is not adjustable. Chiltons shows 5 pictures and none are like mine. Trying to figure out if tensioner pulley is missing , or if the wrong pump bracket was used. Thanks in advance
Old 04-04-2012, 11:24 PM   #2
Re: need picture
According to the diagram I found it should have a tensioner.
Old 04-04-2012, 11:36 PM   #3
tc x 4's Avatar
Thanks Trojan. I'll look 2maro, I think its the alternator bracket that's been changed . I don't remember it having a place on it for the tensioner.
Old 04-04-2012, 11:44 PM   #4
Re: need picture
That's always possible. You never know what some owner before you may have done.
Old 04-04-2012, 11:55 PM   #5
tc x 4's Avatar
U mean like the ratchet strap on it that broke the power steering pump bracket. Lol
Old 04-05-2012, 12:31 AM   #6
Re: need picture
Yeah, but you probably knew about that one pretty quickly.
Old 04-07-2012, 12:29 PM   #7
tc x 4's Avatar
Thanks for the help Trojan . The ap and ac have been removed as well as the tensioner pulley. Question is, i don't have original ac hardware , what part# would I need to locate the ps pump to where the ac was so I can run a tenisioner on it. Where it is now will not have enough clearance between the belt and wp. Car is 1983
Thanks man also there is what looks to b a fresh air hole on each inner fender that possibily go to the breather. Would it make much a difference if I ducted them back in.
Old 04-07-2012, 03:12 PM   #8
Re: need picture
MPS Mustang Parts Specialties may be able to hook you up with an original bracket.
The car probably came with a dual snorkel air cleaner?
Hooking them back up will supply cold air to your engine which will help its performance a bit.
Old 04-09-2012, 05:24 AM   #9
Bane-'s Avatar
Re: need picture
Frpp makes the ps pump relocate brackets, its basically just,a old non ac car bracket. Problems I ran into on mine with the diff pullies I,couldnt find a belt to fit without tensioner squeezing belt together at the water pump. Put a march alt bracket on it, problem solved lol
Old 04-09-2012, 06:43 PM   #10
Filibuster
[QUOTE="tc x 4"]Thanks for the help Trojan . The ap and ac have been removed as well as the tensioner pulley. Question is, i don't have original ac hardware , what part# would I need to locate the ps pump to where the ac was so I can run a tenisioner on it. Where it is now will not have enough clearance between the belt and wp. Car is 1983
here's a few pics when I removed my ac instead of moving the ps pump it moves the tensioner from the alt to the ols ac spot...I dont have the part number but I belive I got a bbk ac delete from summit
ID:	46442   Click image for larger version
XXSTEVEO66 is offline   Reply With Quote
Old 04-09-2012, 07:31 PM   #11
i never saw that setup. cool.
Old 04-09-2012, 08:58 PM   #12
tc x 4's Avatar
Thanks Steve for the info. ? Is the tensioner pushing down on that set up or pushing up. I'm on a cell, hard to see for shur. Gonna look it up on summit, I like doing business with summit one day shipping an no tax. There's so dam many tho .
---------- Post added at 10:58 PM ---------- Previous post was at 10:56 PM ----------
Diff bracket ,or pulley size ?
Old 04-09-2012, 09:14 PM   #13
This is the frpp ac delete.I actually purchased the "off road accessory drive kit" from lrs for about 130$. It came with ac delete,smog delete, ud pulleys, and proper belt. I ended up needing a high amp alternator because with the ud pulleys I had charging issues.
Old 04-09-2012, 09:20 PM   #14
tc x 4's Avatar
Exactly what I'm looking for thanks man.
Old 04-09-2012, 09:22 PM   #15
no problem
Old 04-09-2012, 09:32 PM   #16
tc x 4's Avatar
no problem
I couldn't find it on search, only pulleys. Not finding a kit.
Old 04-09-2012, 09:37 PM   #17
ok this is it. http://www.latemodelrestoration.com/...ehicle=Mustang
but it says 85-93 so im not sure on fitment for you.u maybe able to call them to find out whats different.
Old 04-09-2012, 09:41 PM   #18
tc x 4's Avatar
Will do ,much appreciated
Old 04-09-2012, 09:43 PM   #19
Glad to help.
Old 04-10-2012, 05:24 AM   #20
Bane-'s Avatar
Re: need picture
I think,cuz pre 85 were either a diff rotation waterpump or becuase the mech fuel pump was used? Im not sure.
Trickflow makes the kit to move tensioner had it on a old of mine worked great
Old 04-10-2012, 06:21 AM   #21
I believe you are right.
Old 04-10-2012, 01:14 PM   #22
tc x 4's Avatar
Ya I talked to lrs today, they said ther 85 up kit wouldn't work do to rotation diff. I'll try trick flo, a tensioner on the bottom would work. If not I'll get a fact tensioner and fabricate my own bracket to raise the ps pump. Anyone know how much the height difference between the ps pump and water pump should be for the factory tensioner to work.
---------- Post added at 03:14 PM ---------- Previous post was at 03:04 PM ----------
No luck on trickflows site.
BMW Guys & Gals, I Need Your Help. primer2tone General Car Discussion 4 05-15-2012 10:09 PM
I need MAF conversion for dummies 87blackonblack 1979-1995 Mustang GT 82 04-16-2012 09:40 PM
Just bought a gt and need help UltimateGt 1996-2004 Mustang GT 53 04-12-2012 12:59 AM
need help with fluid decision 5.ohhhhh 2011-2014 Mustang GT 23 04-04-2012 09:00 PM
Need help! 98projectpony Pre-2005 V6 Mustang 5 04-04-2012 05:54 PM
04:40 AM
