86 5 speed vibrates when giving gas at idle - Mustang Evolution
Old 04-05-2012, 05:26 AM   #1
lilrafe87's Avatar
Thought my motor mounts were trashed but they look good. Popped my hood and gave it throttle and the engine didn't rock side to side too bad at all. I don't know where the vibrations are coming from. Could a bad trans mount cause this? I have new wires and new plugs. thanks again
lilrafe87 is offline   Reply With Quote
Old 04-05-2012, 05:27 AM   #2
captain78's Avatar
Check lugs on rims and tires might now be balanced that's just what I'm coming up with off top head
captain78 is offline   Reply With Quote
Old 04-05-2012, 08:15 AM   #3
lilrafe87's Avatar
I failed to mention the vibration happens even parked. When I rev it up is when I notice vibration the most and goes away when idling. Almost as if I have a misfire possibly? New wires, plugs, fuel filter, air filter, new oil, and all sensors new. Trans mount?
Old 04-05-2012, 08:19 AM   #4
Harmonic balancer,flywheel, accessories.anything that spins.
Old 04-05-2012, 04:29 PM   #5
Re: 86 5 speed vibrates when giving gas at idle
+1 and it may be a slight misfire, check your plug wires, cap and rotor.
Old 04-06-2012, 11:24 PM   #6
lilrafe87's Avatar
Found out what might be the problem with my 86. I took it to the shop to run a fuel pressure test and it came back with low pressure. You would think its a bad fuel pump right? Well, I decided to change the pump myself and discovered that one of the fuel lines were kinked
Old 04-19-2012, 03:55 AM   #7
lilrafe87's Avatar
Inspected the harmonic balancer and found that there is rubber behind it that is sticking out. Think this is my answer to the vibration issue I am having?
Old 04-19-2012, 05:49 AM   #8
Yes, but even if it isn't the answer, replace that balancer. The rubber isn't supposed to be sticking out and when it does, vibration can result. Another thing that can result(rarely does, thank goodness) is an "escape" so to speak. Your balancer can come apart... Ya don't want that to happen.
All41 is offline   Reply With Quote
Old 04-19-2012, 03:13 PM   #9
lilrafe87's Avatar
Defiantly don't want that to happen. I have the car parked and I won't drive it till I know I've fixed the balancer. Thanks for the tips.
Old 04-19-2012, 07:06 PM   #10
Inspect the balancer closely upon removal.
I had one crack the snout and a piece broke off and ended up in the oil pan.
Old 04-20-2012, 10:15 AM   #11
lilrafe87's Avatar
Inspected and all was good. Balancer came off as easy as it went back on. She runs great now. Almost too good lol thanks everyone for your help. Now I need to convert to maf! If anyone is selling a maf kit cheap, hit me up on here. Thanks again
Listen up!!! Gas prices!!! FORDGT14 The Bar 47 05-13-2012 06:46 PM
Gas tank issues BelieveInAndr3w 2005-2010 V6 Mustang 13 04-09-2012 05:27 PM
Idleing when it starts laVey420 1979-1995 Mustang GT 8 04-06-2012 11:05 AM
loud squeal noise when certain rpms? Cobra209 SVT Mustang 13 04-06-2012 05:42 AM
Looking at buying tires soon Mile high JDF Mustang Wheels & Tires 2 04-04-2012 11:33 PM
08:40 PM
