am i about to lose 3rd - Page 2 - Mustang Evolution
Old 04-10-2012, 07:56 PM   #36
it shouldnt grind just skipping 3rd. i would go about 30-40 in second give or take then try it.
Old 04-10-2012, 07:56 PM   #37
90fox's Avatar
Ive been trying to. Just the issues of mentioned. Plus before mom wouldn't let me use garage. And its my dd. U did do some work on my f100 cause it wasn't my dd. I'm morw confident tackling cosmetics. If I mess that up it will just look bad lol not affect driveability
90fox is offline   Reply With Quote
Old 04-10-2012, 07:57 PM   #38
90fox's Avatar
Sounds good that's about where I thought.
Old 04-10-2012, 07:59 PM   #39
Re: am i about to lose 3rd
If you don't know for sure if you are low on fluid I wouldn't be driving it anywhere until I was sure it had enough.
Old 04-10-2012, 08:01 PM   #40
90fox's Avatar
I dont think any coolant out of exhaust. I have glass packs/cherry bombs whatever you wanna call them with turn down pipes behind
---------- Post added at 08:01 PM ---------- Previous post was at 08:00 PM ----------
Coolant level seems ok. Just not in res. No temp probs
---------- Post added at 08:01 PM ---------- Previous post was at 08:01 PM ----------
Oh wait nm trans fluid duh
Old 04-10-2012, 08:06 PM   #41
good point.but i also wouldnt get under the car with no jack stand.
Old 04-10-2012, 08:06 PM   #42
tc x 4's Avatar
+1000 we got off topic, u gotta get the plug out dude. Try a bigger ratchet, or put a piece on pipe on the one u have. Best penetrating oil on market is called Kano kroil .
Old 04-10-2012, 08:08 PM   #43
or aero kroil. yes we strayed. thats why he have trojan to get us back in line. plug out!
Old 04-10-2012, 08:09 PM   #44
90fox's Avatar
Lol yes we did kinda. Ill look around for bar or different ratchet.
Old 04-10-2012, 08:09 PM   #45
also if you use the box end of a wrench over the ratchet it can help you get leverage.get the plug out and let us know what u got.
Old 04-10-2012, 08:15 PM   #46
90fox's Avatar
I think space under car is most my prob. I lifted up back pass side first, tires not off ground. Tried front same but then jack in way. Then moved to under engine area. Ill get pen stuff give it another go maybe tomorrow. I'm off during day.
---------- Post added at 08:15 PM ---------- Previous post was at 08:14 PM ----------
Was looking for wrench, but didn't attemp cause mind to frazzled to figure best way going about it
Old 04-10-2012, 08:18 PM   #47
tc x 4's Avatar
If u have a habor frieght around, u can probably get stands for $10
Old 04-10-2012, 08:25 PM   #48
90fox's Avatar
Ya we have a farm and fleet I wanted to check. Otherwise they're 30 at my store...meijer.
Old 04-11-2012, 11:02 AM   #49
90fox's Avatar
Just limped in 2nd to shop to look at coolant on bell housing and oil pan first. Then look into trans rattle. Conaenses seems to be prob throw out bearing. Any idea how much damage that would be at trans shop?
Old 04-11-2012, 11:50 AM   #50
Probably just a guess as shops vary, but around 3-600$ maybe .the job requires pulling the tranny.which is actually isn't to hard to do but will take a at least a few hours labor.
Old 04-11-2012, 11:55 AM   #51
90fox's Avatar
Sounds good not as xtreme as feared. If something else say they wanna rebuild, prob figure out way to park long time and get new
Old 04-11-2012, 03:28 PM   #52
90fox's Avatar
On way to pick up. He said was leaking from timing cover rolling down and spraying where u saw it. He checked fluid in trans..was full. Says coolant not getting in There. No charge
He isn't trans guy but thinks synchro in 3rd not lining up right. Gonna limp back home park then ill have to get to trans shop. Said if cost is xtreme he has a t5 in shed hell sale me for 300. I'm contemplating just getting, but don't know where will put or didn't ask if its everything...trsns self,clutch,shifter. If shifter mines a short throw prob have to swap
How much does a trans weigh?... if your in north I'll. Youngs auto in lakemoor rt 120
Old 04-11-2012, 03:36 PM   #53
Trans weight is around 75 lbs maybe.I would get that one for 300.a rebuild will cost over a thousand$ probably.it will probably not come with a clutch.
I would get that trans.save for a clutch kit which will be a little over 200-250$ then get an adjustable clutch cable kit for around 100$ or less.then some new fluid for 25$. That is just what I would do and rough estimates of the costs.you could always check your clutch when you take off the trans, but imo I would just change it while the trans is out.
Old 04-11-2012, 04:01 PM   #54
90fox's Avatar
Precisely. I called back because ya figured it would cost more than his trans to fix mine. He said the same thing save for a clutch and they'll put all in just swap shifters. Cause god forbid fix it or even buy his and install and have clutch go. I did see a ram clutch kit w flywheell and bearings for 350 via lrs.
---------- Post added at 04:01 PM ---------- Previous post was at 04:00 PM ----------
Why an adjudtable clutch cable
Old 04-11-2012, 04:05 PM   #55
the adj cable is not neccesary but will help dial in your clutch and make adjustments easier.
the flywheel may or may not be neccesary.i usually wait to see what it looks like before i buy the flywheel.as long as its not pitted/grooved to bad you can clean it up.but some people will change the flywheel automatically when doing a clutch.
Old 04-11-2012, 04:17 PM   #56
90fox's Avatar
Ill look into cost diff. I think when looked before ut was under 200 for just clutch
Old 04-11-2012, 05:05 PM   #57
You do want the clutch kit.it comes with tob bearing,pilot bearing, etc etc.but not sure on the flywheel until you see what it looks like.
Old 04-11-2012, 10:27 PM   #58
90fox's Avatar
Ya that's way I go comes w flywheel too. So unless anyone knows of ram clutches are garbage. I have some time so ill look elsewhere. Prob go to a junkyard try to find seat. Of course then eventually ill have to get all of them so not mismatched unless find grey one.
Old 04-12-2012, 06:19 AM   #59
90fox's Avatar
Okay as far as the trans I might buy from this guy someone rain on my parade brought the point if its been sitting for a year and a half should I worry bout to seal's have dried out and I'm just gonna be leaking as soon as in
Old 04-12-2012, 07:14 AM   #60
tc x 4's Avatar
Fix what u have
Old 04-12-2012, 07:32 AM   #61
90fox's Avatar
I would imagine that would cost at least what he'd sell me his for prob much more. If I was gonna go that route you can get new for 1400
Old 04-12-2012, 09:08 AM   #62
90fox's Avatar
Read some reviews on ram clutches, mostly all good except for one. And he was running 650hp plus and beating it on track. I have no intentions of going that high. No intentions of anything forced just na.
Old 04-12-2012, 10:10 AM   #63
That's usually similar to reviews I read. Example :" I went through 3 king cobra clutches.I'm only pushing 500hp.they are garbage." The king cobra is only rated for 400hp. Duh!.
Maybe before you buy the trans you could talk your mechanic into saying that he will help you if it leaks? That is if you trust him.
Old 04-12-2012, 11:28 AM   #64
90fox's Avatar
I trust him. Only sitting about year. Called trans shop as well said prob not likely seals dried up. I asked about them putting new seals in, said hour pr so labor plus seals. I'm gonna chance it don't think ill have a prob. Besides money is pretty non existent to me. Don't see why not but hopefully can keep my old trans for a backup I could have rebuilt if needed. Come to think of it that might be dumb need somewhere to put and if needs total rebuild not worth it well see
Old 04-30-2012, 12:08 PM   #65
90fox's Avatar
Just ordered my clutch...ram hdx master kit. Hopefully have no probs have to get a hold of mech to bring trans to shop and he's in jury duty. Dropping off thurs don't see why but needs to be fixed by 14th. Rents going on vac for 2 weeks nothing to fall back on if I have probs. They're taking their car in tomorrow hopefully that done by wed eve or ill have to steal bros bike. I love riding but haven't in prob couple years, that might be kinda rough riding 15 miles one way first time out
Old 05-07-2012, 07:21 PM   #66
90fox's Avatar
Got back finally . Verdict start up sounds little different. Not bad just sounds cleaner and muffled. He fixed or gerri rigged seat for me on his own nc. Shifting wise, clutch doesn't really seem firmer but catches a lot Quicker. Almost stalled 1st few times already. Still going to baby for while still scared, don't know how long break in period on clutch is. And I guess I didn't have short throw in it. He just switched out trannies. Seems same though 2nd feels like slightly down and over, my other seemed more straight down I think. So if your In northern I'll and see a ugly primer grey loud fox lets see some horns
Empty hole where the stock CD player used to be. Bamman Mustang Audio & Video 6 04-12-2012 06:39 PM
Convert to GT/CS front or..? CYCLON37 2011-2014 V6 Mustang 15 04-05-2012 03:49 PM
ANYONE thinking about buying headers! 02NightmareGT 1996-2004 Mustang GT 36 04-05-2012 10:29 AM
Blow my 2011 5.0 or buy a Fox Body and go to work on it? JG5.0 2011-2014 Mustang GT 14 04-05-2012 10:22 AM
How to Clean Your Engine Blackedout Mustang Paint, Appearance & Detailing 35 04-04-2012 07:57 PM
07:55 PM
