Intake 86 - Mustang Evolution
Old 04-05-2012, 09:00 AM   #1
NateNasty's Avatar
Intake 86
I need to get a new intake mine cracked would a cobra or gt40 that says its for 87-93? I have an 86 but I think the intakes are the same the one I'm looking at looks like this
NateNasty is offline   Reply With Quote
Old 04-05-2012, 09:13 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Intake 86
you can use that intake if you use the upper and lower... but upper you have pictured wont match to your factory 86 lower
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
86 5 speed vibrates when giving gas at idle lilrafe87 1979-1995 Mustang GT 10 04-20-2012 11:15 AM
Cold air intake Musdoyurtang 2.3 Mustang 5 04-07-2012 08:16 AM
No air intake temperature sensor? DaYanks4Ev Pre-2005 V6 Mustang 15 04-05-2012 01:35 PM
Boss Intake or Fuel Problem? SilverBullet12 2011-2014 Mustang GT 14 04-05-2012 12:15 PM
SOLD! Comp Polymers Upper Box Intake for GT40/Cobra Lower Trojan Horse Mustang Parts for Sale and Wanted 4 04-04-2012 08:08 PM
10:18 PM
