Ok I'm going from the aode to a T-5. TheT-5 is out of a fox body, my car is a 94 do I have to change the input shaft and bell housing or will it work the way it is???
make sure u swap ur speed sensor from your aode to your t-5 so your speedo stays accurate, and try to re-use your sn95 driveshaft with the foxbody t-5...
ur prolly already doing the above mentioned... but i just wanted to throw that in there, just in case.
no, a driveshaft is a driveshaft... i said use the sn95 cause its gaurenteed correct length for the car. you always keep the driveshaft with the car whenever possible. you wont have a vibration. ive done 3 swaps... went from t-5 to aod and ive never run into issues.
But an aode to a t5 is no different you have a an-95 as well as a fox body I just read something about a vibration do to a smaller counter weight but if you've done it with out switching the input shafts and stuff than I believe ya lol thank you for the info cuz I have the 89 bell housing and t 5 together so you just saved me about 200 bucks
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
