Runs good but stalls after warm start up - Mustang Evolution
Old 04-06-2012, 09:34 PM   #1
Ironman121388's Avatar
Hello all! I have a 1988 mustang 5.0 gt conv. And I'm having a issue. The car starts up fine when cold and will have a steady idle. It will drive good as well. But when I shut the car off after running it and start it up it will stall, I can keep it running by holding throttle, if I hold throttle for a min I can get the car to idle on its own but the rpm jumps up and down.....Tps is at .96v and just replaced iac and have 10.1 ohms. So those are good. Any suggestions? And I smoked it to see if I have any vacuum leaks, didn't find any and put computer to it and have no codes.
Ironman121388 is offline   Reply With Quote
Old 04-06-2012, 11:31 PM   #2
Re: Runs good but stalls after warm start up
Check your EGR system for vacuum leaks, clean and insure the valve is working.
Old 04-07-2012, 08:37 AM   #3
It won't hurt to check your fuel pressure. It atleast will get that possibilty out of the way
Robbie94gt is offline   Reply With Quote
Old 04-07-2012, 08:46 AM   #4
I smoked the system. No leaks were found, I will check and make sure nothing is clogged and will check fuel pressure, thanks guys!
Old 04-07-2012, 09:15 AM   #5
87blackonblack's Avatar
check your coil its a 25 $ part i had same problem recently cold would start and run when it was warm it would spit and stutter then die!
87blackonblack is offline   Reply With Quote
Post up some pics of your 96-04 Mustang! FORDGT14 Pictures and Videos 4668 02-23-2018 08:58 PM
Funny noise when i start engine Csnow99gt 1996-2004 Mustang GT 25 07-10-2017 12:52 PM
I could use some help making up my mind 5pointOh 2011-2014 Mustang GT 11 04-07-2012 07:10 AM
All perttied up! Dustin11 1979-1995 Mustang GT 9 04-06-2012 05:40 PM
All cleaned up Rolltide Pictures and Videos 12 04-06-2012 02:02 PM
12:19 PM
