4 lug rear disc - Mustang Evolution
Old 04-08-2012, 07:16 AM   #1
4 lug rear disc
What do I need to make a rear end out of an 88 turbo coupe thunderbird work in my 90 lx? Master cylinder? Proportioning valve? I found one not far from my house for a good price and I would love to have 4 wheel disc
Matt90lx is offline   Reply With Quote
Old 04-08-2012, 07:55 AM   #2
I ain't for sure but it should bolt right up. If I had a fox body I would go find me a 94-98 gt or v6 and get the back axels and the back brake assemily from it. It will swap right over. Then u would have disk brake in the back with 5 lugs. And u also can swap out the front spindles to also make the front 5 lug. But me personally if your Rearend is in good shape. I wouldn't even bother to swap the Rearends.
Robbie94gt is offline   Reply With Quote
Old 04-08-2012, 07:59 AM   #3
I just put 4:10s in mine and put all new brakes on it last fall before I put it away for the winter, I just saw the t/c rear end for sale and thought it would be nice to have rear disc instead, thanks for the reply
Old 04-08-2012, 08:14 AM   #4
Re: 4 lug rear disc
The Turbo Coupe rear is wider, but as I remember, it bolts directly in and while most probably don't, you should verify the necessity of replacing the master cylinder along with any lines possibly needed. If available, get the one off the T/C, if for no other reason, to have a core when you need or choose to replace it. You'll also know that the one you're buying matches the one the T/C came with, if it's really different than the Mustang(I'd think it is a bit different inside).
If you can, at least examine the T/C so you'll know if it appears notably different.
All41 is offline   Reply With Quote
Old 04-08-2012, 08:18 AM   #5
Ill have to look up the difference in master cylinders, the guy with the rear end only has the rear end so I have nothing else to look at. Do you guys think I'll see a big difference in braking or is it even worth doing the swap?
Old 04-08-2012, 03:52 PM   #6
Re: 4 lug rear disc
You will definitely notice a difference in braking power.
IMO the only real negative is the additional width which will limit your wheel and tire selection even more than just the 4-lug pattern will.
You will need the master cylinder and the proportioning valve for the swap.
Disk brakes use different volumes of fluid and the rear brake pressure needed is less than drum brakes.
Old 04-08-2012, 07:56 PM   #7
That's some very good info, thank you. I'm going to start gathering parts, including the rear end. Thanks
GOT REAR ENDED!!!! mcvicar04 1996-2004 Mustang GT 28 04-08-2012 07:37 AM
Ford genuine 5 lug Cobra wheels AgentOrange Mustang Parts for Sale and Wanted 2 04-06-2012 09:11 AM
96 SVT Cobra Rear quarter window and rear window louvers. Any good ones? Spiney SVT Mustang 4 04-05-2012 08:41 AM
Rear Axle Shaft Sycopath80 2005-2010 V6 Mustang 4 04-04-2012 03:25 PM
7.5 rear end Surffer227 Pre-2005 V6 Mustang 43 03-31-2012 09:56 PM
11:27 PM
